87 Cutlass Blower only works on high - NOT resistor
Old December 4th, 2018, 12:34 PM
grmchne78's Avatar
I swapped in a new resistor based on lots of posts suggesting that was the culprit. My blower motor only works on high- well sort of... it also seems to have a mind of it’s own, a couple times with all controls in the off position it started working at what I believe to have been lower speeds all on its own. In those instances I could cut the car off and get out with keys in hand, the blower would still be running- any help is appreciated
grmchne78 is offline
Old December 4th, 2018, 12:42 PM
grmchne78's Avatar
Maybe I should stress, a new resistor made no difference
Old December 4th, 2018, 02:42 PM
Olds Fever
CRUZN 66's Avatar
I suggest checking the blower relay and/or the connector to the relay...
CRUZN 66 is offline
Old December 5th, 2018, 01:58 AM
The resistor is functional only on the lower speeds. If you have high only, check the relay. It bypasses the resistor block and supplies full battery voltage to the blower motor.
matt69olds is offline
Old December 6th, 2018, 04:31 AM
grmchne78's Avatar
The relay fixed it, thanks!
Old December 6th, 2018, 02:46 PM
Olds Fever
CRUZN 66's Avatar
Good to hear you were able to fix the problem...
CRUZN 66 is offline
Old December 7th, 2018, 06:13 AM
grmchne78's Avatar
Some call me hard headed but I drive my cars, my every day car is this 87 Cutlass everything works, good heat, ac, tilt, delay wipers, good sound system. It does everything a new car does at virtually no cost. I’m 52 and never made a car payment for my transportation. I have always tried to get my wife a newer car for her safety and reliability. My Olds is a great car and I would take it anywhere right now. It has 200K and I ain’t scared!
Fastmax32168
October 14th, 2018 11:01 AM
Jon442
January 30th, 2018 01:33 PM
96powerstroke
September 11th, 2016 05:38 AM
ljam02
May 25th, 2012 09:25 PM
mhood
August 12th, 2011 10:18 AM
Quick Reply: 87 Cutlass Blower only works on high - NOT resistor
