Go Back  ClassicOldsmobile.com > Repair & Restoration > Electrical
87 Cutlass Blower only works on high - NOT resistor >
Old December 4th, 2018, 12:34 PM
I swapped in a new resistor based on lots of posts suggesting that was the culprit. My blower motor only works on high- well sort of... it also seems to have a mind of itís own, a couple times with all controls in the off position it started working at what I believe to have been lower speeds all on its own. In those instances I could cut the car off and get out with keys in hand, the blower would still be running- any help is appreciated
grmchne78 is offline
Old December 4th, 2018, 12:42 PM
Maybe I should stress, a new resistor made no difference
Old December 4th, 2018, 02:42 PM
Olds Fever
CRUZN 66's Avatar
I suggest checking the blower relay and/or the connector to the relay...
CRUZN 66 is offline
Old December 5th, 2018, 01:58 AM
The resistor is functional only on the lower speeds. If you have high only, check the relay. It bypasses the resistor block and supplies full battery voltage to the blower motor.
matt69olds is online now
Old December 6th, 2018, 04:31 AM
The relay fixed it, thanks!
Old December 6th, 2018, 02:46 PM
Olds Fever
CRUZN 66's Avatar
Good to hear you were able to fix the problem...
CRUZN 66 is offline
Old December 7th, 2018, 06:13 AM
Some call me hard headed but I drive my cars, my every day car is this 87 Cutlass everything works, good heat, ac, tilt, delay wipers, good sound system. It does everything a new car does at virtually no cost. Iím 52 and never made a car payment for my transportation. I have always tried to get my wife a newer car for her safety and reliability. My Olds is a great car and I would take it anywhere right now. It has 200K and I ainít scared!
Jon442
January 30th, 2018 01:33 PM
96powerstroke
September 11th, 2016 05:38 AM
Octania
March 11th, 2016 07:08 AM
mhood
August 12th, 2011 10:18 AM
Luckyme1870
Aurora
July 26th, 2007 05:05 AM
Quick Reply: 87 Cutlass Blower only works on high - NOT resistor
Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
