Blower only works on high
Old Jan 30, 2018 | 12:28 PM
Jon442's Avatar
Gearhead
On my '69 Cutlass (non-air car), the heater blower only works on the highest setting. Is there a relay for the lower settings, or do I need to check for something else?
Old Jan 30, 2018 | 01:07 PM
frankr442's Avatar
Classic resistor failure.
Old Jan 30, 2018 | 01:33 PM
X2. The resistor is by far the most likely cause. Non-A/C blower motors are powered directly from the switch on the dash - there is no relay. Start by pulling the connector off the resistor in the HVAC box on the firewall. Look for signs of overheating or burned contacts. Remove the resistor from the box and look at the crimped connections and resistor wires for corrosion or breaks. If this all looks good, with the key in RUN check for voltage at each of the terminals at the resistor connector with the switch moved through the positions.
96powerstroke
Sep 11, 2016 05:38 AM
Octania
Mar 11, 2016 07:08 AM
oldspackrat
Nov 18, 2012 07:21 PM
mhood
Aug 12, 2011 10:18 AM
Luckyme1870
Aurora
Jul 26, 2007 05:05 AM
