84 Cutlass Supreme Low battery/charge Ligh wont shut off
My alternator is brand new and charging but the charge/low battery light wont shut off. I can disconnect the battery and the car will stay running. I am not using the ECM or 307 emissions. I have a stock olds 350 wit 2004r and it runs great. It buzz and the light will get brighter when I press on the brakes or the accelerator. So I am pretty sure it is a wire loose or crossed under the dash. I just wanted to know if any one has a starting point I can go from. I forgot to mention it wont buzz unless its in gear. Also my check engine light is on because I have everything disconnect for the emissions and I am not using the computer for my engine. I pulled the fuse for the ecm to see if it would make it turn off which it didn't. Should I just take the bulb out or paint it black? Thank you for your help in advance.
it is not good practice to disconnect the battery on a running vehicle-that can instantly cook an otherwise good alternator. the instantaneous load dump can fry other electronics on the vehicle too as the alternator's output voltage skyrockets.
bill
bill
304forest
January 31st, 2015 12:37 PM
