72 Cutlass Ignition Switch Lock
Old Jul 23, 2022 | 12:49 PM
dream66's Avatar
Cory
72 Cutlass Ignition Switch on a NON-tilt column.
The key switch stopped rotating into the LOCK position a few days ago when floor shift was selected to PARK
Yesterday the switch would not rotate to OFF from the RUN position with the floor shift selector in any position. Jiggling the switch finally released to the OFF position after momentary selecting START with associated momentary bendix teeth grind. Switch still will not rotate to the LOCK position.
I checked the back drive linkage and it appears that nothing has changed. The key switch does not seem to push in or spring outward to allow the switch to rotate to the LOCK position.
I guess I'll have to pull the steering wheel and have look inside the column but I"M SKEERED. Never monkeyed with an in-column switch before.
I'm fresh out of dynamite. Any ideas?
Old Jul 23, 2022 | 04:25 PM
You said you checked the backdrive linkage, but have you tried manually rotating the steering column collar behind the key cylinder counter clockwise? Grab it and twist it, then try to remove the key. It doesn’t take much slack in the linkage for the collar to not rotate quite far enough when moving the shifter into Park.
Old Jul 23, 2022 | 05:27 PM
dream66's Avatar
Cory
Interesting. I've never noticed the collar moving when shifting the floor shifter. I'll take a look and get back to you.
THANKS !!!
Old Jul 23, 2022 | 05:38 PM
dream66's Avatar
Cory
The collar will not rotate counter clockwise any further than the backdrive rotates it by selecting PARK with the floor shifter. I'll raise the car on the lift and see if I can adjust the backdrive enough to release the key switch.
Old Aug 9, 2022 | 10:17 AM
dream66's Avatar
Cory
UPDATE: The failed part was the key lock cylinder
prohandze
Feb 22, 2016 06:00 AM
Ramirez007
Apr 27, 2015 07:45 AM
Sampson
Mar 15, 2014 08:11 AM
grt05
Apr 29, 2009 04:36 AM
Benny Blanco
May 25, 2008 04:17 PM
