71 taillight socket replacement??
Old Apr 17, 2019 | 01:10 PM
71DP's Avatar
Is it possible to replace the taillight bulb socket in a 71S? Looks like they are crimped and this socket is damaged to the point that the nubs won’t lock in. I had first thought that it was because the springs were compressed but it’s the actual socket itself.
Old Apr 17, 2019 | 01:21 PM
What is a twilight bulb?
Old Apr 17, 2019 | 05:53 PM
71DP's Avatar
Taillight bulb sorry
Old Apr 17, 2019 | 06:03 PM
You are referring to a standard 1157 socket I believe. The tail light is a dual action bulb (instead of a 1156 single action).
I've replaced both on more vehicles than I can remember I've owned - they do rust out, and go bad.
There should be numerous types available with several different attachment options. The attachment options would apply in determining just how much damage, rust etc. is around the standard attachment point of the 1157 socket. Some get really bad. Yes, you can remove the entire 1157 socket and replace w/ a new socket.
I would generally snip the wires at a good length which you can work with so you can easily reattach the wires with good wire crimp splices and be sure to use some rubber heat shrink wrap around your splices. Pull out the old 1157 socket, and insert the new 1157 socket. It should more or less 'push' in or 'snap' in, if you will. Do a search for 1157 sockets & purchase the one most appropriate for your needs.
Old Apr 17, 2019 | 06:32 PM
JVCCutlass
Apr 21, 2025 08:33 AM
Loucobalt
Jul 22, 2019 06:14 PM
Vintage Chief
Jan 4, 2019 01:34 PM
truckman5000
Jun 4, 2017 04:36 AM
jamac
Nov 15, 2014 03:47 AM
