70 oil pressure gauge pegged
Hello, oil pressure gauge is pegged all the time, key on or off makes no difference. Can I ground the sending unit wire to check the wiring and gauge? I know this works with temp and gas gauges, but it doesn't make a difference on my oil pressure gauge. I'm trying to see if it's just a bad sending unit or the actual gauge or wiring problem. Any info is appreciated.
70OLDSCUTMC218
Aug 3, 2013 07:05 AM
