70 oil pressure gauge pegged
Old Jun 5, 2017 | 11:53 PM
dsouthard's Avatar
Hello, oil pressure gauge is pegged all the time, key on or off makes no difference. Can I ground the sending unit wire to check the wiring and gauge? I know this works with temp and gas gauges, but it doesn't make a difference on my oil pressure gauge. I'm trying to see if it's just a bad sending unit or the actual gauge or wiring problem. Any info is appreciated.
Old Jun 6, 2017 | 03:33 AM
If you remove the wire from the sender and ground the end of the wire, the gauge should go to 0. If it does buy a new sending unit.
Old Jun 6, 2017 | 08:37 AM
dsouthard's Avatar
Thank you, that's what I thought but it doesn't move the gauge. I'll check the wire next and see if it's broken.
Old Jun 6, 2017 | 06:12 PM
dsouthard's Avatar
Problem found, wire pulled loose behind the gauge. Works great now.
Old Jun 6, 2017 | 06:31 PM
Well done.
roscopdoggy
Dec 9, 2016 07:12 AM
Olds Dad
Jul 11, 2014 04:56 AM
70OLDSCUTMC218
Aug 3, 2013 07:05 AM
foreverolds
Dec 1, 2012 07:07 PM
tecar442
Jun 14, 2009 06:08 PM
