'68 442 "lazy" fuel gauge?
Old Mar 30, 2013 | 08:08 PM
4speedBench's Avatar
Ok, tried searching this on here as I figured not a new item...but nothing?
Recently, I've noticed when I start the car and operate it for about 15 minutes the fuel gauge is pegged at FULL. In reality, I know I happen to have a 1/2 tank. Eventually, it "drops" to 1/2 reading. At first I thought this might be the float "sticking" from condensation, etc. but the fact that it is at FULL rather than stuck at 1/2 (as i would assume) makes me wonder?
Other variable is that I recently had to remove speedo to extract broken cable line and wonder if I "disturbed" something on the gauge panel?
Thoughts?
Old Apr 17, 2013 | 06:40 PM
Holiday350's Avatar
i had the same problem with my 78 delta and it turned out to be a bad ground on my fuel tank sending unit. whenever it was raining the fuel gauge would work and then when dry it would cut out and have the same exact symptoms you are describing.
Old Apr 21, 2013 | 05:50 PM
c9az's Avatar
the sending unit for a 72 olds is a driect fit 65 - 70 model can be bought for thirty dollars on ebay where the new old stock ones are over two hundred dollars my sending unit on 67 delmont got stuck and i installed a 72 no problem
the differants is the old stily is in a can and the 72 is on a float
JPMDaddy
Jan 31, 2020 04:01 AM
Oldsragger
Dec 5, 2014 04:59 PM
gearheads78
Oct 8, 2012 09:59 PM
blaker1
Apr 16, 2012 04:45 AM
