67 cutlass front turn signal sockets
Old Jun 13, 2016 | 07:40 PM
SnakeBit's Avatar
Car Whisperer
these don't seem to be removable...is that true? not sure if they are supposed to, but the pins in the bottom do not move, i.e., they don't seem to have a spring behind them to crush down" when the bulb is inserted, of they do, mine are all the way down which results in the bulb not making solid contact. I was replacing all the bulbs in the car as we put it back together and the old ones were almost "welded" in the sockets. destroyed one of the bulbs getting it out. any tips would be appreciated as now, at least one of them (haven't tried the other one yet) with the new bulb...nothing happening. thanx.
Old Jun 13, 2016 | 08:04 PM
Spray some wd40 on the spring loaded terminals and loosen them up. You may have to straighten the wires at the sockets.
Old Jun 14, 2016 | 06:55 AM
The sockets are swaged into the housings. They are not designed to be removeable. You can replace them with some work.
Old Jun 14, 2016 | 10:36 AM
SnakeBit's Avatar
Car Whisperer
I tried some pb blaster...didn't seem to do anything. will try it again. thanx.
what I thought. Thanx.
Old Jun 14, 2016 | 02:52 PM
Chesrown 67 OAI's Avatar
I ended up wrapping a small strip of aluminum foil around the base of my bulbs to tighten them up in the loose sockets to maintain good contact and they now work fine.
Old Jun 14, 2016 | 03:16 PM
Octania's Avatar
might be time to restore the lamps or buy others.
The wires need to be free to slide thru the insulating passage.
spring might be shot.
New inserts with wires, spring, and holder disk are available.
Complete dismantling, cleaning with evaporust and / or hot viegar & salt might be in order. Wire brush as needed. Silicone lube upon reassembly.
Old Jun 14, 2016 | 03:33 PM
Can anyone tell me how to get them apart without ruining them? They are strongly crimped together.
Can someone tell me how to get them apart without ruining them? They are strongly crimped together on the 67s.
Old Jun 14, 2016 | 08:30 PM
SnakeBit's Avatar
Car Whisperer
would have to be careful so that the two wires aren't grouped so that the turn signal and parking lamp are both not illuminated. thanx for the tip.
who sells the kit? I looked at OPGI and found nothing for the parking lamps except the lens and gasket. thanks for the info!!!
Old Jun 15, 2016 | 06:38 AM
Oldsmaniac's Avatar
Had a similar problem with one lower taillight on my 67. I used a dremel and ground the securing bead off the socket to remove and got a generic push in new socket and adapted the plug off the old socket to the new one. Not hard to do and works fine.
Old Jun 15, 2016 | 09:37 AM
m371961's Avatar
http://www.delcity.net/store/Bulb-Pi...0.h_810383.t_1
Here are the pigtails. I have not used them in your app. but worked in others.
Remove old, clean socket, install, solder and shrink wrap connection. Just keep wiring orientated with proper connection, or before soldering test and make sure turn signal is brighter then parking light.
Old Jun 15, 2016 | 12:15 PM
SnakeBit's Avatar
Car Whisperer
I have an extra set of the sockets for the rear lights that I did not use since no matter how I adjust the prongs, they don't grab like the oe. i compared those to the parking/turn signal ones in the front and the socket is larger so will have to find something the same size. thanx for the input!!!
Thanx!!!!!!!!!!!
costpenn
Jun 24, 2015 10:38 PM
Mr Nick
May 27, 2015 11:06 AM
nukesec1
Apr 24, 2011 03:38 PM
KZ442
Dec 7, 2009 06:11 PM
slowolds
Jun 28, 2009 06:55 AM
