67 442 horn only clicks after replacing battery
Hi I just replaced my battery on my 442 and now the horn just clicks, but not horn sound. Probably just the horn relay. Any ideas on what happened?
I may have it was a tight fit. I cannot see in front of the battery as it slips under it. I take it I should remove the battery and shine a flashlight there? Not sure where you are referring. Thank you for replying.
I see what happened. Some of the jostling knocked off a lost connection at the horn itself. It barely is holding on there. Wow with the new battery, the horn is pretty loud! Is that normal or should I tone it down.
By the way, they sold me these circular pads to go on the terminals. Do they work much? Thanks guys.
https://itstillruns.com/inexpensive-...n-5770493.html
