3rd gauge options
Old Mar 18, 2020 | 08:54 PM
Mossy's Avatar
3rd gauge options
Seeing as my 71 Cutlass S has a blank 3rd gauge, I’m trying to figure out if there are options for a functional gauge? Is there something original I can put in there or only aftermarket? If so, what would they be? Thanks
Old Mar 18, 2020 | 09:30 PM
svnt442's Avatar
OK so you have the fuel gauge, the speedometer, and then a blank. That "pod" on the right is for the tach. The factory one is a tach/clock combo, but there was one made that was a tach only, but I don't think it is made anymore.
It was common to have an aftermarket tach in that hole that would stick out past the bezel as that is the cheapest option, but it's just not as clean of an install as one that fits in the dash properly.
Old Mar 18, 2020 | 11:16 PM
That is actually the spot for the optional clock. With the Rallye Pack, there was a clock/tach combo. As Randy said, lots of folks (I am one of them) stick an after market tach in that location.
This thread has some pictures of installed tachometers:
https://classicoldsmobile.com/forums...e-dash-133867/
Old Mar 19, 2020 | 06:45 AM
Mossy's Avatar
Ok thanks guys. Would an original tic tach gauge work if I found one at a reasonable price?
https://www.ebay.com/itm/1970-72-Old...-/350505517483
Old Mar 19, 2020 | 08:45 PM
Mossy's Avatar
Or am I better off finding something aftermarket based off pricing? Don’t really need it to look original but I don’t exactly want it to stand out
Old Mar 19, 2020 | 10:11 PM
4speed455's Avatar
I installed an aftermarket Autometer 3-3/8 tach. It came out okay.
Old Mar 19, 2020 | 10:21 PM
oldsmobiledave's Avatar
Aftermarket 3 and 3/8ths tach or a factory tach. Be forewarned that OEM tachs are not accurate.
Old Mar 20, 2020 | 02:25 AM
svnt442's Avatar
They can be adjusted. Mine was off a little when I got the car and I used a good digital meter with a tach to adjust it.
JoeyOldsmobile
May 16, 2021 10:49 AM
Neil F85
Jun 16, 2019 08:48 AM
Hank
Dec 20, 2012 04:22 AM
PGH Cutlass
Oct 31, 2011 12:59 PM
Pinner
Apr 1, 2007 11:48 AM
