Sun Pro Tach for empty clock gauge in Dash
Old Mar 18, 2019 | 09:37 AM
sjay1989's Avatar
I have been searching the forums to find the size of a tach that will fit in dash (my car has a blank gauge where the clock goes). Research indicates 3 3/8" gauge will fit quite well. I came accross this gauge locally being sold:
https://www.kijiji.ca/v-other-auto-p...ationFlag=true
Seller is not able to figure out the size or provide any information listed on the gauge. For those of you that have experience with Sun Pro, does this seem like it will fit flush? I found this picture (attached) and was looking to do a clean install similar to it..
If the gauge i am looking at wont fit well, is there a Sunpro model number similar to that in the picture that someone can refer me to. Thanks!
Old Mar 18, 2019 | 12:06 PM
That looks like the one in my car. Be aware that it won't fit flush as shown above - you have to make some sort of holder to get it like the pic. In my car, i just put a couple wraps of electrical tape around the perimeter then friction fit it into the gauge face plate. I have some parts to mount it behind the face plate but too many other projects take precedence.
Old Mar 18, 2019 | 12:41 PM
11971four4two's Avatar
MOTORHEAD
The SUN Super Tach
Is about the size
Modify as needed
Old Mar 18, 2019 | 01:15 PM
don71's Avatar
same but different
I have the same set up. I wrapped electrical tape around it to make it snug. That was at least 25 yrs. ago. I might have put a zip tie around it....I've slept since then.
Old Mar 18, 2019 | 02:42 PM
tru-blue 442's Avatar
Old School Olds
I have this one if interested. I dropped it in from the front of an old housing I had. Sits in there ok. You may be able to make it work.
Old Mar 18, 2019 | 05:04 PM
RetroRanger's Avatar
72 Olds CS
The pic in the OP is mine. In this case i put it behind the lens of the dash as well as have the lens on the tach, that makes it hard to see in some conditions. Someday i will either take the lens off the tach or off the dash probably the former. IIRC i used a similar method w a zip tie or electrical tape or a hose clamp in an old speedo housing.
The link looks like the same size tach but i dont like how the needle points to less than zero makes me wonder if it works.
theres many other aftermarkets tachs available in that size as well.
Old Mar 18, 2019 | 05:18 PM
Be aware that Bosch bought the Sunpro line and is making them with the Bosch logo on them now. The 2 tachs you posted are the same basic size.
Old Mar 18, 2019 | 06:42 PM
Sun Super Tach II - ebay
Old Mar 18, 2019 | 07:08 PM
truckman5000's Avatar
W30
PM if u want to buy mine on my car, I'd rather not remove now, but it's on my list of things to do.
Old Mar 18, 2019 | 07:17 PM
72 Olds CS
https://www.ebay.com/itm/Sunpro-3-3-...ty!01475!US!-1
this one seems to be as close as can be to the OP pic.
I have several others (not for sale) that ive picked up over the years they all appear to be nearly identical including the linked to and pictured above super tach II, a super tach and what may be the start of the line super tach thats all metal !!!
Old Mar 20, 2019 | 07:50 PM
sjay1989's Avatar
Does the bezel around the tach come off in order to install? I am considering this one, basically the new SunPro but with a Bosch logo:
​​​​​​https://www.jegs.com/i/Bosch-Actron/...T7901/10002/-1
If the bezel need to be removed I might as well buy the version without the chrome bezel.
Old Mar 20, 2019 | 08:23 PM
72 Olds CS
depends how you do it, it looks like don 71 has his bezel still on and same w mine, mine would be better w out the lens but w no bezel it may look unfinished
Jabenge
Jan 28, 2018 11:33 AM
68conv455
Non-Olds Engines
Jul 8, 2017 05:41 PM
yamahondarider
Apr 26, 2015 08:18 AM
defiant1
Feb 12, 2010 08:41 AM
Mister
Jan 14, 2008 07:36 PM
