1986 Olds 98 Reg. No Spark
Old Mar 3, 2013 | 01:02 PM
Kay Lofton's Avatar
Good day everyone I have a 86 Olds 98 with no spark. It had spark before the timing chain was changed...I assume. After no spark. My mechanic said the chain was lined up properly. We changed the Ignition Module, the Crank and the cam sensor and still no spark. Its been hesitating for a while then one day it just stopped running. So the Mechanic said it was the timing chain. The chain gear was ran down. There was a lil clip he was describing that was looked beat up im not sure what it was. Is there anything esle required when changing the chain besides the timing chain gear set?
Old Mar 8, 2013 | 10:52 AM
BILL DEMMER's Avatar
Just the facts...
is there 12 volts at the fat pink/red wire(B+) going to the distributor cap(referenced to the engine block ground)? is the engine ground cable connection clean and tight?
bill
Old Mar 8, 2013 | 11:33 AM
bill
Bill,
Better check your CSM. The 1986 98 is the FWD version. The only available engine was the 3.8 liter V6 with sequential fuel injection and a distributorless ignition system. No cap, no fat pink/red wire.
Old Mar 9, 2013 | 11:59 AM
Just the facts...
noted. i didn't read the post when i was awake-my bad.
i'm sure the op found your response very helpful.
so, to get this thread back on the right track, is there power to the ignition module under the coil pack? did a wire in the vicinity possibly get damaged during the process?
iirc, there is a ground wire or 2 that connects to one of the module/coil pack bracket mounting bolts.
there were issues with the coil packs, and to a lesser extent, the ignition modules.
bill
Cman7713
Jun 5, 2014 07:49 PM
oldrelics
Mar 25, 2014 07:44 PM
kds 69 442
Dec 15, 2013 06:46 PM
anthonyc
Aug 26, 2010 03:43 PM
redvettemike
May 26, 2009 01:09 AM
