1970 442 Engine and Light Harness Connector ID
Old May 1, 2026 | 09:40 PM
70_455's Avatar
Hello
Finally getting to Rewiring the engine Compartment in my 70 442 Convertible, AC car with Internally Regulated Alternator.
I bought the Harnesses from M&H and Id like to know if anyone can ID the two plugs pictured below.
The first picture is a short double tan pigtail pigtail right out of the harness and the second/third is a round connector black/tan stripe and Green/white stripe.
Lastly, in the 4th pic, the Wiper motor wires look as if the light blue wire is a bit short and will make a bulged loop when connected. Would anyone know if this is is correct or did they cut the light blue wire short and they should all be the same length?
Thanks!
Old May 2, 2026 | 06:48 AM
The round rubber connector goes to the transmission case plug. The brown/black wire is the kickdown signal to the solenoid, the green/white wire is from the transmission pressure switch to the TCS system. Yes, this pigtail is built into every harness no matter what trans you have. On MT cars, that connector still plugs into the trans switch for TCS operation.
The single brown wire is the pigtail for the optional under hood light.
All of this is shown in the wiring diagram in the Chassis Service Manual.
Old May 3, 2026 | 07:37 AM
70_455's Avatar
Thank you Joe!
It looks like Everything matches up except one for one the pinouts on the Bigger of the 2 firewall clamshell connectors.
So on the diagram below my blue wire on the M&H harness is where the arrow is (one over).
Would you know if this is an error in printing or an error on the Harness. I have no way to know its wrong until i pull off the booster (which seems almost impossible to get to the bolts)
Thanks again
2qwk4u442
Jan 12, 2025 10:31 AM
Chuxter
Apr 5, 2023 03:02 AM
Feb 27, 2022 08:53 AM
Doug Carner
Aug 26, 2020 05:16 PM
Microreedy
Jul 19, 2016 08:21 PM
