1969 Tic Tok Tach help
Old May 29, 2022 | 09:13 AM
over my head's Avatar
I’ve got a 1969 442 with the TTT I’m in the middle of installing.
I’ve got a constant hot wire going to the batt hook up on the back.
I’ve got the lighting hook up on and working.
I’ve got the tach wire hooked up and it’s ran out to under the hood.
I haven’t hooked a ground wire to the ground terminal yet.
here are my questions
1: the clock isn’t ticking, is this because I haven’t ran the ground wire yet? I’ve verified I’ve got power to the batt post when the car is off.
2: I’m running a Mallory unilite dist as a stand alone unit with a coil and a ballast resistor. That distributor doesn’t have a place for the tac. So where do I hook the wire from the tac? The negative side of the coil?
Old May 29, 2022 | 09:32 AM
The clock won't work until you supply a ground - which would be achieved when you mount the TTT to the dash panel grounding strap. You "could" run a simple wire from a ground point anywhere on the dash panel (anywhere honestly) to the TTT casing to validate operation prior to "mounting" into the dash panel.
Any chance you happen to have the 1969 CSM. There is a section for installation of the TTT in the back section under Accessories.
Old May 29, 2022 | 09:34 AM
Yes, you need a ground. It's the same as if you connect only the positive cable to the battery.
Yes, connect the tach wire to the negative side of the coil. The Unilite is just an electronic on/off switch, with exactly the same function as the points.
prlynch01
Apr 20, 2022 10:25 PM
Maui442
Apr 17, 2021 04:42 PM
JimpeBoy
Aug 20, 2019 09:43 AM
trucker442
Jun 22, 2018 10:22 AM
toro455
May 9, 2017 08:07 PM
