Tach wiring?
Tach wiring?
Aug 19, 2019 | 10:43 AM
JimpeBoy
Aug 2010
Mölnbo, Sweden
Tach wiring?
Bought a used tach/clock for my 1969 442 but Im not reallt sure I've got it right? Can someone please tell me if this is the correct wiring?
JimpeBoy
Find More Posts by JimpeBoy
Aug 19, 2019 | 07:40 PM
matt69olds
Jan 2010
central Indiana
The gauge grounds thru the housing, no need to run a ground wire to the stud with the nut. The rest of your diagram is correct.
matt69olds
Find More Posts by matt69olds
Aug 19, 2019 | 08:11 PM
rcorrigan5
Randy C.
Feb 2009
Albany, OR
Orange wire is 12v, grey wire is for dash lights, brown wire has 2 amp in-line fuse and goes to negative side of coil.
Randy C.
rcorrigan5
Find More Posts by rcorrigan5
Aug 20, 2019 | 09:43 AM
JimpeBoy
Aug 2010
Mölnbo, Sweden
Thanks! Just hooked it up and it works great!
JimpeBoy
1972 tic toc tach wiring
1972 "U" code
07:30 AM
Tick tock tach install?
Phantom197
07:42 PM
1968 wires\connectors FROM the Tach
rhett838
Jun 2, 2017
10:16 AM
Tachometer installation question
toro455
May 9, 2017
08:07 PM
69 Rally Gauges w/ Tach Wiring
PHILATLAS
08:36 AM
Tach Wiring
10:31 PM
