1969 442 Transmission Kick Down Wire
Old May 5, 2017 | 05:22 PM
RROLDSX's Avatar
I've reviewed my photos, my ASM, and my CSM and I can't see where the clip and the wire path to the TH400. Can anyone give me some help on this?
Old May 5, 2017 | 06:59 PM
classicmuscle442's Avatar
Not sure if turbo 350 is same, just pulled engine/trans from '70 cutlass. The wire came out like the accelerator cable thru firewall and down to front side on passenger side of trans.
Old May 5, 2017 | 07:04 PM
RROLDSX's Avatar
Thanks Chris but my TH400 has the connector on the driver side.
Old May 5, 2017 | 08:46 PM
tru-blue 442's Avatar
Old School Olds
Not sure what you are asking about, but there is a switch on the accelerator pedal that is the kick down for the TH 400. These pics are from a 70 442 w/a 400 turbo. The 69 b/b with the 400 is the same type unit. Mine are anyway. Hope this helps some.
Old May 5, 2017 | 09:02 PM
RROLDSX's Avatar
Sorry, I should have been more specific. I'm looking how to route the black and orange wire that plugs into the driver side of the transmission. There is also a brown plastic clip that clips somewhere along the firewall to hold the wire.
Old May 5, 2017 | 09:07 PM
Old School Olds
Oh, ok. I will look in the am and see if I can find it for you. If it's the same for the 70.
I haven't pulled the trans on it yet, so maybe it's still where it should be.
Randy, I took a look this morning and mine was just hanging from the harness. No clip to be found.
Old May 6, 2017 | 07:09 AM
It's not. TH350 uses a mechanical cable. TH400 (and Jetaway) uses an electric solenoid.
Old May 6, 2017 | 07:14 AM
RROLDSX's Avatar
Thanks fellas I guess I'll just let hang it as well. I'm going to a car show tomorrow and should be able to spot something there if anything should be different I'll post a picture.
Old May 6, 2017 | 08:39 AM
Yellowstatue's Avatar
Seems to me that there is a white plastic clip to hold the wire, that fastens to the side of the trans case just above the kick down switch.
Old May 7, 2017 | 07:08 PM
RROLDSX's Avatar
Thanks Yellowstatue, that sounds right to me.
ThePackRat
Jan 2, 2014 08:52 PM
DRXOLDS
Aug 24, 2011 10:47 PM
salisbury99
Jul 5, 2008 05:26 PM
Scout
Dec 28, 2007 05:40 AM
J&P Chassis
Dec 31, 2006 04:16 PM
