1969 442 Transmission Kick Down Wire
I've reviewed my photos, my ASM, and my CSM and I can't see where the clip and the wire path to the TH400. Can anyone give me some help on this?
Not sure what you are asking about, but there is a switch on the accelerator pedal that is the kick down for the TH 400. These pics are from a 70 442 w/a 400 turbo. The 69 b/b with the 400 is the same type unit. Mine are anyway. Hope this helps some.
Sorry, I should have been more specific. I'm looking how to route the black and orange wire that plugs into the driver side of the transmission. There is also a brown plastic clip that clips somewhere along the firewall to hold the wire.
Oh, ok. I will look in the am and see if I can find it for you. If it's the same for the 70.
I haven't pulled the trans on it yet, so maybe it's still where it should be.
Randy, I took a look this morning and mine was just hanging from the harness. No clip to be found.
Thanks fellas I guess I'll just let hang it as well. I'm going to a car show tomorrow and should be able to spot something there if anything should be different I'll post a picture.
