1968 442 No Head lights, No Tail Lights No Charging
Old June 23rd, 2020, 12:56 PM
peterskunk's Avatar
My friend just got a 1968 Olds 442, we made the engine by just adding gas and new battery but No Head lights, No Tail Lights No Charging. We installed a new alternator but still the same issue. it looks like i share circuit is causing this problem but i don't know where i can start diagnosing.
even though the wiring looks untouched, there's some evidence of some work on the ignition switch (not installed hanging under the dash board)
any input will be much appreciated. thanks
peterskunk is offline
Old June 23rd, 2020, 01:21 PM
Sugar Bear's Avatar
Start with cleaning, tightening and adding grounds if needed from the battery to the fender, and from the cylinder head to the firewall.
Is there voltage to the lights that don't work?
Good luck!!!
Sugar Bear is online now
Old June 23rd, 2020, 02:07 PM
There is a red wire that runs from the horn relay power stud to the bulkhead connector that supplies power to the cabin. Check the fusible link on that wire. Also clean and check the connections of all the wires connected to the power stud.
oldcutlass is online now
Old June 23rd, 2020, 05:09 PM
BackInTheGame's Avatar
You may not know that in '68 the voltage regulator is separate from the alternator. The regulator is on the firewall. It may have died. Good luck in troubleshooting! I'm sure you guys will have it sorted out shortly. Then you have to come back and tell us what the trouble was.
BTW, Welcome to Classic Oldsmobile! If you buddy is not too shy, share up some pics of his new ride!
BackInTheGame is offline
Old June 24th, 2020, 05:20 AM
Let's back up.
First, you can completely remove the alternator and regulator from the car and the lights will still work, so obviously those are not related to the problem with the lights.
Second, how do you know you have no charging? Does the GEN light come on? Does the battery run down? Have you actually used an ammeter to check current output of the alternator while running?
As usual, my first recommendation is to stop randomly replacing parts and perform some troubleshooting first. Get a factory service manual and LOOK at the wiring diagram. See if everything is connected properly. See if mice have chewed through a critical wire. Use a voltmeter or test light to figure out where the voltage stops in each circuit. Test the fusible link.
joe_padavano is offline
Old June 24th, 2020, 01:26 PM
peterskunk's Avatar
i just replace the alternator because the Gen light was on, i checked with a volt meter the new alternator and it read 12.5 on idle and 13.0 when add a some rev to the engine, GEN light still On.
Will keep you guys posted thanks
Old June 24th, 2020, 01:44 PM
What is the voltage across the battery when its disconnected from the car?
L69
February 27th, 2021 05:37 PM
roye182000
May 28th, 2020 12:20 PM
73aussie455
September 23rd, 2014 04:10 AM
Debha
June 18th, 2014 10:46 AM
jr's67
September 13th, 2010 06:13 AM
Quick Reply: 1968 442 No Head lights, No Tail Lights No Charging
