1966 cutlass hei power source
Old Sep 24, 2022 | 02:29 PM
Ranzan's Avatar
Getting There
Other than taping into the ignition wire what other options can I use to tie in my 12 awg power wire ?
Old Sep 24, 2022 | 02:38 PM
You can run the wire to the IGN spade terminal in the fuse block. Cap and stow the original distributor power wires.
Old Sep 24, 2022 | 02:40 PM
Ranzan's Avatar
Getting There
there is no ign spade on the 66 I wish there was lol
Old Sep 24, 2022 | 02:45 PM
66SportCoupe's Avatar
Orange wire with connector near the wiper motor on the firewall. It is switched 12v.
Old Sep 24, 2022 | 02:47 PM
Ranzan's Avatar
Getting There
the power wire to trans ?
Old Sep 24, 2022 | 02:52 PM
Yep
Old Sep 24, 2022 | 02:54 PM
Ranzan's Avatar
Getting There
awesome thanks … last thing I wanted was to tap into the ign harness lol
Old Sep 24, 2022 | 06:09 PM
wingbat's Avatar
Go to the fuse box. There is usually an extra slot for an ignition controlled wire. Use your test light.
Old Sep 24, 2022 | 06:43 PM
Why? That's the easiest thing to do. Just replace the resistor wire with copper and you're done.
Old Sep 24, 2022 | 06:45 PM
66-3X2 442's Avatar
That wire is cut off if it's a stick car.
Old Sep 25, 2022 | 09:39 AM
Ranzan's Avatar
Getting There
So I went ahead and tied into the pink ign wire from the back of ignition . 12awg wire is hot at 12v with key on .
soon as it cranks voltage drops to 8 so not getting enough for spark
Old Sep 25, 2022 | 09:42 AM
From Post #9:
Old Sep 25, 2022 | 09:44 AM
Ranzan's Avatar
Getting There
From Post #9:
I read your post earlier Joe are you talking the resistor wire than ran to the coil ?
Old Sep 25, 2022 | 09:45 AM
Ranzan's Avatar
Getting There
Like I said I am no electrical genius by any means
Old Sep 25, 2022 | 09:49 AM
The resistor wire is why the voltage is only 8 volts in RUN. There are two wires running to the coil, a copper one that provides 12v when the key is in START and a resistor wire that provides 8-9v when the key is in RUN. You need to connect both of them to the BATT terminal on the HEI, but you first need to replace the resistor wire with copper to get the full 12v in RUN.
Old Sep 25, 2022 | 09:54 AM
Ranzan's Avatar
Getting There
so even though I ran a fresh 12 awg from the ign wire I still need covert the existing resistor wire ?
Old Sep 25, 2022 | 09:57 AM
I can't tell from those photos where you ran that wire from, but if you are only getting 8 volts, there's something wrong.
Old Sep 25, 2022 | 09:59 AM
Ranzan's Avatar
Getting There
I soldered the 12awg into the pink ignition wire just before the ignition plug
Old Sep 25, 2022 | 10:02 AM
Ranzan's Avatar
Getting There
Might seem like a dumb question but can the car crank with a faulty ignition switch ?
Old Sep 25, 2022 | 10:05 AM
At the ignition switch? That's the wire that feeds the resistor wire. By leaving the resistor wire in place, you may have an unintended loop that keeps the resistor in the circuit. Are the old coil wires connected to anything? Unless you care about not cutting the original harness, you should separate the pink and black/yellow wires at that horseshoe connector and insulate both of them.
Old Sep 25, 2022 | 10:24 AM
wingbat's Avatar
I can't remember if there are two wires going to the Started solenoid. If there are, one provides 12 volts to the coil on start only. If not, the 8v wire from the ignition is the coil wire. Do you have a resister on that car? There must be an 12v ignition spade on the fuse block. Or tie into a ign wire coming out of the fuse block. just carefully scrape the insulation away and wrap a wire around it. Those blue conectors don't work well.
Old Sep 25, 2022 | 10:27 AM
The black/yellow wire is the resistor bypass wire and goes to the R terminal of the starter. The pink wire is the resistor wire that is fed by the pink IGN wire at the bulkhead connector.
Old Sep 25, 2022 | 12:33 PM
Ranzan's Avatar
Getting There
Yea just behind the plug
Joe not to sure what you mean by horseshoe where the wires join together for the coil ? If so it bumps volts to 9 1/2 when I cut the end off
Or do you mean by the horn relay ? Or by the body connector at the firewall
Old Sep 25, 2022 | 01:24 PM
Old Sep 25, 2022 | 01:26 PM
Ranzan's Avatar
Getting There
I did cut the horseshoe off but still only 9.5 on crank
Old Sep 25, 2022 | 01:31 PM
Use the Power window or antenna terminal at the bottom of the fuse block.
Old Sep 25, 2022 | 01:33 PM
Well, I have no idea how that is possible. Just so I'm clear, that wire reads 12.5 V or so with the key in the START position and 8-9 V in the RUN position?
Old Sep 25, 2022 | 01:44 PM
Ranzan's Avatar
Getting There
I will take a quick video here in a bit
Old Sep 25, 2022 | 02:04 PM
Ranzan's Avatar
Getting There
Video was to big to load so a couple of pictures
Cranking
Key on
appreciate the help on this Joe … I’m stumped
Old Sep 25, 2022 | 03:09 PM
Ranzan's Avatar
Getting There
So I went through the whole fuse panel …
anything key power reads of 12 v
but not one single thing on the car will read over 9.7 🤷🏻‍♂️ On crank
Old Sep 25, 2022 | 03:16 PM
  #31
66-3X2 442's Avatar
I believe those lose 12V when cranking.
Old Sep 25, 2022 | 03:41 PM
  #32
Loaded68W34's Avatar
What does the battery voltage show when cranking (at the battery terminals)? Do the headlights dim when cranking if they are on?
Old Sep 25, 2022 | 03:50 PM
  #33
Ranzan's Avatar
Getting There
Volts read 11.5 cranking .
can’t tell with the headlights since I’m by myself and in daylight
Old Sep 25, 2022 | 04:02 PM
  #34
danktx's Avatar
I used the resister wire that goes to the stock coil to trigger a relay and ran the relay power wire from the distribution point on the inner fender. Somewhat convoluted but can be readily changed back to stock configuration since no permanent changes is made to the harness. The relay control wire does not have to be 12V. Power for the relay is coming directly from the battery so minimal voltage drop.
Old Sep 25, 2022 | 04:28 PM
  #35
Ranzan's Avatar
Getting There
thanks for the heads up but it seems I’m not getting voltage though out the whole car above 9.5 cranking
Old Sep 26, 2022 | 05:12 AM
  #36
That's a completely different problem. ASSUMING your battery is good, go clean every connection. Pay attention to the wires on the stud at the horn relay. I've had a problem there in the past.
Old Sep 26, 2022 | 07:18 AM
  #37
Ranzan's Avatar
Getting There
thanks Joe going to go through all the cables and grounds ..
hopefully an easy fix cleaning everything
Old Sep 26, 2022 | 09:05 AM
  #38
Ranzan's Avatar
Getting There
Cleaned all power wires cables battery grounds and straps .. still no difference ..
there is a power wire from body harness to the horn relaywith a factory looking fusible link could that be the problem ?
Falkon
Aug 15, 2022 10:30 AM
Toocool
Jul 28, 2021 02:02 PM
rodan
Jul 19, 2020 08:24 PM
Jannebill
May 14, 2013 09:01 PM
Olds luvr
Nov 21, 2007 05:24 PM
