12v constant power for led tail lights
wrong wire?
I don't see how digital stuff can exceed the dome lite fuse capacity.
What you call white may be gray GROUND wire from dome lites thru door switches.
I suggest the orange wire that feeds the trunk light. Should be hot all the time. Check the current draw of your load, either by the label/ instructions that came with them or by your own ammeter. I would be suprised if it draws more than 1-2A. LED's are on the order of mA each I believe.
I am not sure why constant 12V power is needed, but if it is, the original tail or stop circuit will not do- they are powered only when you activate the tail or stop lights.
wondering what happens if the digital tail lites lose everpresent power?
It seems odd that these lights would require a constant hot (sounds like a design flaw or cop-out), but if that's the case, then, as others have said, the orange wire is the way to go.
FYI, if the voltage drops, the running lights seem to work, but the directional signals do not.... I found this out due to a bad battery... (2 months old and it had a bad cell!) I doubled checked today and the power comes from the orange wire... (trunk light) The wiring diagram in the service manual is great! you definitely need one! get an original with COLOR wiring diagram!
Alex I like your color combo! That is they wayI will be going with mine...
Oldssupreme
April 3rd, 2015 08:36 PM
