12v constant power for led tail lights
Old May 17, 2015 | 09:34 AM
Alex72cutty's Avatar
I'm installing led tail lights and other than the fuse box is their any other areas I can find a 12v constant power?
Old May 17, 2015 | 10:09 AM
Why do you want constant power? The lights would never turn off.
Old May 17, 2015 | 10:58 AM
It's for the digitalis led lights. I have them hooked up to the dome lights wires (white)in the trunk. Fuse constantly blows.
Old May 17, 2015 | 12:01 PM
RandyS's Avatar
Damn, those are some strange lights - did you mean Digitails?
Old May 17, 2015 | 12:06 PM
RandyS's Avatar
You need to run a wire to the fuse panel and piggyback to a terminal that is constant on.
Old May 17, 2015 | 12:13 PM
Lol. Yes.
Old May 17, 2015 | 01:35 PM
Octania's Avatar
wrong wire?
I don't see how digital stuff can exceed the dome lite fuse capacity.
What you call white may be gray GROUND wire from dome lites thru door switches.
I suggest the orange wire that feeds the trunk light. Should be hot all the time. Check the current draw of your load, either by the label/ instructions that came with them or by your own ammeter. I would be suprised if it draws more than 1-2A. LED's are on the order of mA each I believe.
Old May 17, 2015 | 01:39 PM
RetroRanger's Avatar
72 Olds CS
Why not use the existing tail light wire it has power all the time and as Octania pointed out LEDS should draw less current than incadecsents
Old May 17, 2015 | 02:00 PM
Octania's Avatar
I am not sure why constant 12V power is needed, but if it is, the original tail or stop circuit will not do- they are powered only when you activate the tail or stop lights.
wondering what happens if the digital tail lites lose everpresent power?
Old May 17, 2015 | 03:34 PM
mrhotrod's Avatar
battery or fusebox are your choices for always hot but you better have it fused .
Old May 17, 2015 | 05:31 PM
kitfoxdave's Avatar
If I remember correctly, my digitails are powered from the orange wire...
Old May 17, 2015 | 08:04 PM
Octania's Avatar
Orange to trunk light should be
1) constant 12V
2) fused already
Please consult your car's wiring digram within the factory service manual.
Old May 17, 2015 | 08:44 PM
It seems odd that these lights would require a constant hot (sounds like a design flaw or cop-out), but if that's the case, then, as others have said, the orange wire is the way to go.
Old May 18, 2015 | 08:11 AM
Ok. Thanks everyone. I'll look at it today and post a picture
Old May 18, 2015 | 04:26 PM
kitfoxdave's Avatar
FYI, if the voltage drops, the running lights seem to work, but the directional signals do not.... I found this out due to a bad battery... (2 months old and it had a bad cell!) I doubled checked today and the power comes from the orange wire... (trunk light) The wiring diagram in the service manual is great! you definitely need one! get an original with COLOR wiring diagram!
Alex I like your color combo! That is they wayI will be going with mine...
Old May 20, 2015 | 11:05 PM
Well lights are working very good. Thanks everyone for your help.
Old May 20, 2015 | 11:07 PM
Thank you!! At first in didn't care to much for it,but now I love it.
Oldssupreme
Apr 3, 2015 08:36 PM
TripDeuces
Nov 19, 2014 05:33 PM
LAolds
Aug 19, 2013 11:33 AM
Texas69
Feb 11, 2012 05:21 AM
veltboy618
Jan 7, 2009 05:31 AM
