will a 75 cutlass steering wheel fit a 73 delta 88 royale?
Old Aug 1, 2013 | 06:57 PM
eudaman's Avatar
I have been looking all over for a steering wheel for my 73 delta 88 royale but to no avail. Came across a 75 cutlass steering wheel in same color as my interior....wondering if will fit? i do not see why not but thought i would ask to be sure before plunking down the cabbage.
Old Aug 1, 2013 | 09:34 PM
nsnarsk65cutlass's Avatar
I believe so.
Old Aug 2, 2013 | 07:10 AM
Assuming the D88 does not have the telescoping column, yes it fits.
Old Aug 2, 2013 | 08:55 AM
eudaman's Avatar
The d88 has the tilt column but not telescoping.
Old Mar 9, 2014 | 06:19 AM
Carl, uk's Avatar
what thread/size is it on the delta 88 ?? thinking about changing mine...
Old Mar 9, 2014 | 06:31 AM
66400's Avatar
All GM steering wheels are pretty interchangable within these year groups. In these year groupings all the steering wheel hubs will match the steering column in size. All years will swap around but the steering wheel hub will be smaller or larger where it meets the column.
66 and earlier (no 4 way flasher system on column)
67-68 (4 way flasher on column)
69 and newer (ignition switch on column)
Henry
73deltaguy
Mar 21, 2015 09:32 PM
eudaman
May 19, 2013 06:18 PM
Tony72Cutlass'S'
Mar 2, 2011 12:44 PM
ddx77
Jul 17, 2010 08:32 PM
