73 delta 88 royale - need steering wheel column cover
Old May 15, 2013 | 08:57 PM
eudaman's Avatar
recently bought a 73 delta 88 royale, and she needs some help in the interior. need the plastic steering wheel column cover, door panels, and interior light bezels. have been searching online to no avail....help!
Old May 17, 2013 | 03:14 PM
ThePackRat's Avatar
Big Daddy No Bucks
Are you talking about the piece of trim that attaches to the bottom of the dash & wraps around the bottom of the column ?.
(above the white "X" in the pic below)
If so I should have an NOS one in black along with an NOS vent insert as well.
Old May 17, 2013 | 03:27 PM
eudaman's Avatar
no, not that piece....see attached for image of the missing piece(s)
Old May 17, 2013 | 04:56 PM
ThePackRat's Avatar
Big Daddy No Bucks
Looks like the base of the steering wheel is the cracked part with the column needing some paint ?.
Old May 18, 2013 | 07:33 AM
eudaman's Avatar
Ahhhh...so the column is just needing paint? i had thought it might have a plastic cover. thats good news i guess, can just pain the column.
Old May 19, 2013 | 04:26 PM
junqueboi's Avatar
Registered Loser
Looks like the column is out of a '71-'74 full-size Buick. There is a small rubber ring/collar that fills the gap between the column and the instrument panel that's missing. I doubt you'd want to remove the column from the car to install one though.
If it were my car I would find an Oldsmobile column with the ring & correct shift, tilt, & turn signal stalks.
Old May 19, 2013 | 06:18 PM
Grace Stinespring-Welch's Avatar
you might want to remove it to paint it anyway , so you might want to find the rubber piece too, or find the original olds collum.
starfire
Dec 9, 2021 08:21 PM
ros6872
Mar 28, 2014 09:48 AM
eudaman
Mar 9, 2014 06:31 AM
oddball
Mar 4, 2014 06:42 AM
RPMRestoAndCustom
Apr 18, 2013 02:06 PM
