do they make performance parts for the 371
Old Jan 12, 2010 | 06:49 PM
wildwillie1981's Avatar
hey guys, im fixing to fire the 371 engine, that in my 60 88... im gonna run a compression check on it.... then make sure the valves arent stuck.. then fire it up.... if it runs good, im gonna pull it out and clean it up...install new gaskets and freeze plugs, and probably an oil pump.. then re-paint it
was wondering if you can buy a performance cam, and 4 barrel intake for the 371 engines????
Old Jan 13, 2010 | 05:48 AM
rocketraider's Avatar
Oldsdruid
Dang, bo, you ARE an Olds noob, ain'tcha?
You might have to go on vintage speed equipment sites to find it, but you can get about any sort of high-performance or drag racing equipment you could ever want for these engines. These and 394 were VERY popular in Gasser classes and ruled them until the Hemi and Ford Cammer came out.
Old Jan 16, 2010 | 02:02 AM
64Super88's Avatar
Rich from Las Vegas
Ross Racing Engines
1763 North Main Street
Niles,Ohio
44446
330-544-4466 shop
330-720-1282 cell
Old Jan 16, 2010 | 08:12 PM
59-59-59's Avatar
Edelbrock has a 2X4 , 6X2 intake, finned valve covers.. Offenhauser has a 3X2 setup as well as their finned valve covers ( which surprisingly they make new ) Magnetos could be found from time to time on ebay, as well as Hillborn injection units. 4bbl intakes are easy - any '59 - '64 371/394 will bolt up, Ross Racing has an impressive line of parts for the early rockets. Check them out
Old Jan 31, 2010 | 09:49 PM
ed burke's Avatar
rocketlover
Hey, Buy a 57 -58 tripower manifold put a cam in it get chevy, pontiac carbs- not olds carbs, put progressive linkage on it and it will fly.
Rocketlover
Old Feb 3, 2010 | 03:03 AM
rougebeats's Avatar
Registered Grease Monkey
What kind of trans do you have? Im not sure if the roto-hydramatic came on the 1960 88 with the 371, but the transmissions are pretty "stubborn" if you change tv rods and linkage to accommodate a dual quad or tricarb setup. To help answer your question, many hi performance parts and dress-up parts can still be found today and are interchangeable between the 371 and the 394. Best of luck with your Olds! -Rouge
Old Mar 28, 2010 | 03:58 PM
dynamic88371's Avatar
i got a 4 barrel carb and intake for a 60 olds 371 but needs work
Old Mar 28, 2010 | 06:09 PM
well guys... thanks for the replys, but the 371 is toast, freeze cracks all over.... i guess im gonna put a 394 i found in it... laters willie
442b
Wheels and Tires
Jul 3, 2020 10:02 AM
cutlassefi
Nov 28, 2013 12:08 PM
auto_editor
Jul 10, 2011 11:20 AM
84hurst
Jan 25, 2010 07:21 PM
ricdiculus
Mar 16, 2009 07:36 AM
