70 delta 88
70 delta 88
does anyone know where to find parts 4 the b body cars i need a few more things,turn signal switch w/cruise,fender trim 4/front,keyhole emblem 4 trunk, and how can you find out how many convertibles were made in 1970,thanks
Of course, Ken is right on the money with 3095. Pretty small number, really.
Fusicks has a catalog for just the big body Oldsmobiles. Great place to buy.
They have a downloadable catalog on their webpage.
tried fusicks they got a few things on there website 4 the 1970 the parts i need theres stop at 1968 and pick back up at 1971 the olds dealer here in ohio tells me good luck finding them, been finding a few things on ebay every now and then,almost done but a few more things it dont stop me from driving the big beast it still turns heads and a great conversation starter,thanks
I don't think the turn signal switch has anything to do with the cruise other than the lever screws to it. The switch should be available at the big parts stores but they may have to order it.
Rockauto has several switch choices, it's not unusual for them to be cheaper with shipping than most parts stores want for the same exact part.
http://www.rockauto.com/
To do it you need a steering wheel puller and a lock plate remover tool if the key is in the column.
On the trim pieces I've had good luck posting in the parts wanted section here, boneyards, Hemmings, evilbay.
That stuff shouldn't be too hard to find.
www.usapartssupply.com they will send you a paper catalog for free. 1941-1975 parts catalog.... HUGELY useful inventory for all kind of stuff! Lots of hard to find stuff
GM Sportsalvage
Try these guys for the trim. http://www.gmsportssalvage.com/?q=node/509 They have a 1970 98 parts car on the lot here in San Jose, CA. I think most of the front end sheet metal is the same between the 88/98. Not sure on trim. They may also have other stuff that is not on the web site.
70 delta 88
dwsshay . sorry for not replying to you. I am sort of getting tired of giving pictures and prices and never hearing from them again . I have the convert switch $50.00,the trunk key emblem not the best in world $10.00. what fender trim do you need ? the spears or opening trim ? I have the front fender wheel opening trim $35.00 each side. dont have a turn switch for cruise . if you want these let me know . prices DO NOT include shipping . Money order or personal check only.
rocwal
Dan B
rocwal
Dan B
i need the spears,found everything else,but turn signal switch,do you have one w/out cruise it would work for now better than half a handle thats on it,got keyhole emblem its not so good either but it works 4 now thanks,don
Cruise/turn signal lever
This may help broaden your search for a cruise/turn signal lever. I have a 1971 Cutlass wagon project with a cracked cruise/turn lever. I found a column from a 1978 Toronado and the cruise/turn lever looks the same. I've not taken the Toro column apart, but the button on the end and chrome arm visually look the same. I don't know if the 1970 were different than 1971, I can post some pictures if it would help. John
need a cruise lever?
I have an NOS cruise lever. It is not the cheap plastic grooved one with the chrome cap that would be correct but the later heavy smooth metal chrome one with the black cap. It is out of my personal stash of Toro parts. The last three of these I've seen on ebay went for $300(yikes). The proper grooved plastic ones are long discontinued, I saw one a couple years ago on ebay and missed the end of the auction(AARRGGHH!!). I would sell you this one for $160 If your interested call Tom at 2063130238 Thanks P.S. It is your post that triggered me to sign up to this place so thanks for that
JoshF85
Jun 1, 2024 09:20 PM
Dead Reckon
Mar 4, 2016 10:55 AM
Aussie67Delta88Custom
Feb 22, 2008 04:49 AM
