Steering gear box repair?
Old Sep 16, 2022 | 10:22 AM
The_German's Avatar
Hi, I own a 56 Super 88 convertible with power steering.
Seems that there is quite a play in the steering, can you help me to possibly adjust it?
Is it difficult to take the steering gear box out of the car for repair?
The German
Old Sep 16, 2022 | 02:33 PM
70sgeek's Avatar
'72 Cutlass ragtop
At that age probably best to have it rebuilt - trying to adjust even if possible could make it worse.
check this rebuilder out - awesome vendor
HOME | steerandgear
Old Sep 17, 2022 | 01:50 PM
Run to Rund's Avatar
Often you can improve and minimize slop in the steering by making the over center adjustment as in the factory service manual. Hold the screw head in the top cover while loosening the lock nut, then turn the screwdriver clockwise a little at a time, and re-tighten the lock nut.
Old Sep 18, 2022 | 10:27 AM
sysmg's Avatar
If you over tighten it, you can ruin the gearbox. Best left to a professional. If I remember correctly this takes up slack in the shaft, but not in the gears. So if there is play in the gears, you might tighten it too much.
lala5818
Jul 28, 2021 02:26 PM
tgilligan
Suspension & Handling
Apr 24, 2021 05:58 PM
FTolliver
Apr 15, 2018 03:59 PM
oldrelics
Mar 24, 2014 06:02 PM
agtw31
15
Jun 14, 2010 06:01 AM
