Some Smoke
Old Aug 1, 2017 | 09:39 AM
Stephen0523's Avatar
Some Smoke
Hello.
I have a 1984 Delta 88 Royale Brougham with the 307 engine with 115,000kms on it
I am getting some smoke (smells like burnt oil) coming from the carburetor after driving and when the engine is hot.
That smell gets into the cabin when the vent is on.
I assume a gasket or pcv valve might be going but if anyone might have a better idea, please shout out!
File Type: mov
File Type: mov
Old Aug 1, 2017 | 09:46 AM
Check your pcv valve and replace if it hasn't been in a while. Remove your valve cover breather and see if you have severe blow by there.
Old Aug 1, 2017 | 09:47 AM
You can test the PCV valve by removing the PCV valve from the valve cover with the hose still attached. Then you hold your thumb over the bottom of the PCV valve to hear it "click" closed. Sorry I wasn't thinking.
Does the car smoke on start up (worn valve guide seals) or smoke constantly while driving (worn rings or detuned carburetor)? A compression test is the best way to diagnose a worn engine.
Old Aug 1, 2017 | 11:05 AM
Wow, thanks Olds64 for the fast reply!
No smoke on startup and no smoking while driving.
I took the air cleaner items off and noticed a small drip of gas. It almost looks as if the pipe was put on at an angle!
File Type: png
File Type: avi
Old Aug 1, 2017 | 01:22 PM
I was mistaken, the smoke is coming from the the vent at the exhaust manifold.
See the video attached.
Maybe EGR valve?
File Type: png
File Type: avi
Old Aug 1, 2017 | 02:19 PM
Thats probably caused by a valve cover gasket leak.
Old Aug 1, 2017 | 03:14 PM
Yes, I was wondering about the valee cover gasket. I may try tightening to see if the bolts are torque. The Throttle body front bolt were slightly loose also.
Old Aug 2, 2017 | 03:33 AM
Be careful not to over tighten the valve cover gaskets. All you would accomplish is warping the valve covers.
The puddle of gas at the carb seems to be coming from the fuel inlet. That's a common failure point on Q-jet carburetors. It looks like your fuel inlet was installed crooked. Sometimes folks remove the brass filter from the fuel inlet, and fuse the inlet to the carb body with JB weld. Just make sure you run an in line fuel filter.
68conv455
Jun 24, 2010 08:35 AM
1973_442
Dec 15, 2007 05:13 PM
54olds
Nov 27, 2007 05:08 AM
ztim
Sep 20, 2007 04:03 AM
77 oldsMAbrotha
Aug 22, 2007 04:00 PM
