tailpipe smoke
Old Sep 18, 2007 | 07:54 PM
ztim's Avatar
tailpipe smoke
When the engine starts it smokes for less than a minute. What is wrong? I couldn't find anything in FAQ.
thanks
Old Sep 18, 2007 | 08:27 PM
texasred's Avatar
Tom Servo's Stunt Double
If it does it for just a few seconds at startup after standing a while, I'd "best guess" valve guides. While it sits, oil leaks down from the heads and is burned when you first start it up.
C.J.
Old Sep 19, 2007 | 01:09 AM
Huron's Avatar
thanks
It depends on what kind of smoke. If it's white, it's just steam from the water being produced in the combustion process. If it's blue, it's oil. If it's black, it from excess fuel.
Huron
Old Sep 19, 2007 | 11:05 AM
7798's Avatar
...and grey, transmission fluid...
Old Sep 19, 2007 | 03:47 PM
Redog's Avatar
Thick white smoke: Anti-freeze
Blue smoke : Seaver engine wear
Black smoke : burning oil
Old Sep 19, 2007 | 03:52 PM
I agree with CJ. That sounds like classic symptoms of worn valve guides. If it were a worn engine or rings then it would blow blue smoke when you got into it. If it was a detuned carb then you would get a sooty blackish smoke and you would smell the hydrocarbons. If it isn't the valve guides then it could be old valve guide seals.
Old Sep 19, 2007 | 05:56 PM
texasred's Avatar
Thanks, Olds64. I'd agree with Huron, 7798 and Redog if it was for more than "a minute" and since he stated no other symptoms.
Could be wrong...but I'll stick with my answer based on the information provided.
C.J.
Old Sep 20, 2007 | 04:03 AM
ztim's Avatar
Yes, the smoke is whitish. All kinds of things were just mentioned that could be burning, But the valve guides sounds like that it would allow whatever it is to get down there.
So is it detrimental that it get fixed right away? It was a rebuilt 307 that was put in the car... '84 Delta 88 Royale.
TK-65
Jun 1, 2014 10:38 PM
Chris J
Oct 28, 2013 06:03 PM
Oldsmaniac
May 26, 2013 07:05 PM
roamer
May 26, 2011 07:50 PM
OLDSmobility
Jul 30, 2010 09:26 PM
