seeking 78 delta aluminum hood info
hey all, I have heard it mentioned on here that some delta 88s came through with aluminum hoods.. upon lifting mine a few times, it seemed to feel really light but I never thought much of it. I think my car has one as the hinges are aluminum and the lift springs are about half the thickness of my other 70s cars. also, a magnet will not stick so i'm pretty sure it is. what I wondered was whether it was an extra cost option, or just came that way on some cars for other reasons. (time\place of production or any other reason) . I figure this is the place to find the answer! thanks for any info, dave
I'm not exactly sure what the reasons were. I had one as well. I'm told they are really rare, but I sincerely doubt that.
If there was a row of 1978 deltas in the junkyard, I'd guess 1 in 7 has the aluminum hood.
When the car had an aluminum hood it also had the aluminum bracing on the back bumper. I think there were other parts that were aluminum on these cars also but I can't remember what it was. I found them most often on the diesels but do not think that was any kind of factor as to why it got the aluminum parts.
All Olds 260, 307, 350, 403, 400 and 455 pans will fit each other. The Toronado pan is a little differant but will still work on the others. The big block pans were also a little differant but will not affect anything if you use it on a small block.
Thank you, Your the greatest!
My 78 Holiday 88 had a steel hood to start with.
It now sports an aluminum hood taken off a boneyard run of the mill 78 4Dr 88. It had one of the hinges and all of the correct aluminum fasteners and springs. I had to find another hinge from another 78. That was a 79 4dr that was munched in the front, but the hinges were undamaged.
My car did come with the aluminum bumper stuff.
sx455raidercelticfan
August 1st, 2010 08:03 PM
