saving the delta
#41
theirs 12 bolts that hold on the front clip, 2 up front that bolt on the core support, and the rest bolt the fenders to the body, 5 a side. You don't have to remove the inner fenders if you remove the wheels. remove the front plastic inner well guards, theirs also a bunch of wires to pull.
bolts are
1 inside under hood hinges
2 top inside with hood pins
3 open the door near the top, head facing you
4 open door near the bottom, head facing out
5 under the fender head facing down
6 is the 2 front body bolts into core support
got the rear trim on looks nice from 10 feet, well the hole thing looks good from 50/50
bolts are
#42
Well the bouncy spedo was due to the bad cable sending unit that bolts into the tranny.
question? what circuit is the moon roof on? it quit working, or is it a relay or something????
got to take the pass door apart and find out why the door handle doesn't work, it never ends
#43
If the moonroof is powered like other GM cars, the wire come down the left front A pillar. I can't remember if there is a relay for it on the fuse block. Wire colors might be orange and white, it's been a looooong time.
#44
tanks i'll look for it, I remember cutting some wires on that side when I took out the alarm system. the alarm was not working, was a rats nest of wires and making the tail lights not work...
I finished the final sand and buff, put some burgundy pin-striping on it. Had the windows tinted to help with solar gain until the ac is re-done.
The door had a broken plastic clip that held in the handle rod. The door window switch just broke, got a new one from rockauto.
I'm going to put it back on the computer soon, I'm shure that will open a new can of worms:/ theres not nothing I never touched on this project, cruise will be after that.....................
Question???????????
what is the correct color spedo gear drive for a 4 spd auto with 308 gears???????
Question???????????
62Starfire63
May 8th, 2014 12:25 PM
esisson
December 16th, 2009 03:19 PM
