Power Brake Issue
Old Sep 26, 2021 | 07:58 PM
55Oldsmobile$'s Avatar
Power Brake Issue
Power Brake Issue
My '55 came with front power disk brakes that were supposedly installed correctly. We'll at this point we've replaced the calipers, rotors, pads, bearings and seals. We've bleed them and still have issues.
When the cars off the pedal is firm. When the car is on the pedal has almost no resistance. We went to adjust the pedal and the guy screwed the adjuster to the side, not in the center.
I read to take out the tube from the power booster and stick a zip tie down to see if there's fluid. So we did that and there is a tad of fluid and some grease(maybe white lithium) down there.
Not sure if it's the master/power booster or a vacuum issue on the carb/Manifold side
Has anyone has this issue before? Or know what has failed? Thank you.
Old Sep 26, 2021 | 08:29 PM
Did the brakes work before?
Old Sep 26, 2021 | 08:35 PM
Yes they worked before. The car can drive and stop still. Just not getting the firmness in the pedal like you would think. They were similar before as well but had a little more resistance.
Old Sep 26, 2021 | 10:22 PM
Have you checked the rear brake adjustment?
Old Sep 27, 2021 | 05:19 AM
The the only adjuster we've tried was on the pedal
Old Sep 29, 2021 | 08:24 AM
Tedd Thompson's Avatar
Hard to diagnose beings it has been altered, and you don't have history on the components. Like Oldcutless mentioned, check and bleed the rears for air in the lines also the fronts. If it stopped well before what have you changed since it started happening?.... Tedd
Allan R
Apr 30, 2021 03:07 PM
yeahbuddy
Brakes/Hydraulic Systems
18
Oct 11, 2020 11:59 AM
dmruschell
Jun 11, 2016 03:10 PM
rocketdownunder
May 31, 2015 07:02 AM
mikeman
May 20, 2014 02:27 PM
