Poor seal on the convertible header panel. 75 Royale
Old Apr 27, 2015 | 05:34 PM
Icey1966's Avatar
The header panel on my 75 Delta 88 is leaking air when the roof is closed. It's real obvious when it rains and water is dripping from the header. It's definately leaking more toward the center of the header.
I installed a new roof seal last year to fix the problem and while it's better, it's not fixed. I think the header must be bent somehow. It's tight on the ends where the latches are, but looser in the center. I can actually pass a sheet of paper thru to the outside of the car.
Any thoughts? Make a custom seal that's taller in the center? Bend the header panel somehow to get the center tighter to the windshield?
Thanks much for any solution! It's real irritating when hitting bugs at night when the bug guts come floating into the car from the gap in the header panel.
Old Apr 28, 2015 | 12:41 PM
1yesfan's Avatar
have you adjusted the latches to make it pull closed tighter?
Old Apr 28, 2015 | 06:28 PM
Icey1966's Avatar
The latches are tight, perhaps too tight. The issue is that the bow still has a gap in the center that lets air and water thru to the inside.
leroycjr
Body work
May 1, 2015 09:18 AM
69442murph
Jan 28, 2015 07:32 AM
55jes
May 13, 2010 08:36 PM
DAN76
Brakes/Hydraulic Systems
Jul 28, 2009 02:13 AM
Sixoh
Aug 8, 2006 05:11 AM
