need help to ID oil leak
Old Dec 23, 2020 | 04:08 PM
jcor12's Avatar
I am getting this 1950 Olds 88 running after sitting for many years. 5 years ago my Dad replaced the timing gears, timing cover seal, gaskets, etc, but he never drove it after that. This oil originally appeared to come from the front oil pan gasket, so I put some RTV on the spike where it was leaking. The leak moved to a spike above so I put RTV on that as well. The leak is now worse and maybe the leak is coming from the front face onto the pan gasket? The leak gets worse as you rev up the engine.
Where do you think this is leaking from? I have included a video link to my you tube below. I tried to upload the video but no luck with that yet. The video is 21 MB.
Old Dec 23, 2020 | 07:42 PM
Tedd Thompson's Avatar
Sometimes a bad leak like that (and that is bad) will show up as a clean spot where the leak begins, that is if you haven't wipe the area clean in a while. Worth a look and the price is right.... Tedd
Old Dec 24, 2020 | 09:14 AM
jcor12's Avatar
Put a small bottle of UV dye in your oil & visualize w/ a UV black light. They sell both at any automotive store. They have small pen light UV lights inexpensive.
Thanks, great idea . I already have the UV light and glasses from AC work.
Old Dec 28, 2020 | 07:34 AM
sysmg's Avatar
I'm no 50s engine expert, but perhaps he left off the oil slinger, or perhaps the harmonic balancer was severely scored and ruined the front seal. If it's the balancer, you might be able to get a machine shop to sleeve it.
An oil slinger for you car might be this:
USED 1949-1964 OLDS 303 324 V8 CRANKSHAFT WOODRUFF KEY AND OIL SLINGER 88 98 | eBay
Old Dec 28, 2020 | 04:25 PM
jcor12's Avatar
Thanks for the reply. I put some dye in and ran it today. Then I pulled the radiator, see pictures below. Can you tell me what you see there?
Old Dec 28, 2020 | 05:21 PM
sysmg's Avatar
Again, I am no expert on the 50s engine, but that looks like come kind of broken casting. Is that the front cover? Block? or Water Pump? Someone more familiar with this engine might know.
Old Dec 28, 2020 | 05:37 PM
jcor12's Avatar
Thanks for the response. I am also not familiar with these engines. I re-posted in the engines forum to see if it gets more views/responses.
Old Dec 28, 2020 | 05:47 PM
RetroRanger's Avatar
72 Olds CS
Is it the oil pan not seated correctly? You said your dad had changed the timing chain, maybe he didnt get that together correctly?
Old Dec 28, 2020 | 06:29 PM
jcor12's Avatar
Here is a picture of your engine for discussion purposes I see what appears to be the two bolts front of engine driver side. Is this where you found the leak?
Yes, the top picture with the red circle is the front, bottom driver side of the engine, where the oil pan and timing cover come together. The bottom picture is the same but passenger side. The engine dye was evident on the passenger side, less so on the driver side. Either way, I'm pretty well convinced this is the cause of the leak. My best guess is that either the oil pan was damaged or as RetroRanger stated, the oil pan did not get seated properly. Should I pull the timing cover next? or remove the front engine mount?
Old Dec 28, 2020 | 07:10 PM
Charlie Jones's Avatar
Phantom Phixer
It looks to me as though someone tried to remove and replace the timing cover without removing the oil pan first .
One might be able to do that on a Chevy , but definately not on a first generation Olds .
Looks to me as though the pan was badly damaged by the attempt to reinstall the cover .
Old Dec 28, 2020 | 07:28 PM
jcor12's Avatar
It’s a tough call determining exactly what specific area can be seen in your picture. I think this is your timing cover?
Yes that looks like it, better picture with pulley removed
Old Dec 28, 2020 | 07:30 PM
jcor12's Avatar
completely agree...on both sides there is a distinct flat spot (like a screw driver was wedged in to pry)
Old Dec 29, 2020 | 08:06 AM
Phantom Phixer
You're probably going to need an oil pan .
The good news is that 1949 thru 1956 oil pans will fit .
According to the parts book ;
1963 Oldsmobile Parts and Accessories Catalog (Chassis Edition) - ClassicOldsmobile.com
Old Dec 29, 2020 | 08:14 AM
redoldsman's Avatar
Proud Viet Nam Veteran
That thing is not leaking, it is pouring. I think the gang here has pin pointed your problem. Unfortunately you have some work ahead of you. Good luck.
Old Dec 29, 2020 | 08:20 AM
jcor12's Avatar
Thanks for the info. I found one from Toms auto parts in Maine.
Old Jan 2, 2021 | 08:38 AM
jcor12's Avatar
Well I have the pan out. I do not think the oil pan is damaged. Upon inspection, it appears those areas in the top corners are supposed to be shaped that way. The gasket has a right angle shape to it that exactly matches the oil pan. I do believe the leak was coming from the oil pan gasket not seating properly. There are also two tabs in the oil pan gasket kit. Where do they go?
Old Jan 2, 2021 | 09:18 AM
rob1960's Avatar
I believe those small tabs get glued into the gap on each side of the rear main cap. They should be made of cork.
Old Jan 2, 2021 | 09:21 AM
Phantom Phixer
The two small cork "tabs" go on either side of the rear main bearing cap .
Check that pan carefully . It looks like it has been bent and pried on .
Old Jan 2, 2021 | 11:40 AM
jcor12's Avatar
Thanks...I have a new gasket and used oil pan on order. A side by side comparison of the 2 oil pans should make it obvious.
Old Jan 9, 2021 | 07:15 PM
jcor12's Avatar
Where exactly do these 2 cork tabs get placed? Is it where that black rectangle is?
are they “glued” just using black rtv gasket maker?
Old Jan 9, 2021 | 09:20 PM
Phantom Phixer
This is where the two cork tabs go .
A little Permatex here won't hurt .
Old Jan 10, 2021 | 03:40 PM
jcor12's Avatar
Thanks Charlie...I looked there but questioned it because the cork tab provided is bigger than that space. Anyway I had to scrape out the old ones and trim the new ones to fit.
Old Jan 10, 2021 | 06:30 PM
Phantom Phixer
You shouldn't have trimmed those tabs . They are meant to be squeezed into that cavity by the oil pan .
But since you have done so , I would suggest putting a dab of silicone sealer there when you install the pan .
Tiberian Fiend
Jan 18, 2021 05:45 PM
Brownie12
Apr 26, 2020 02:22 PM
danktx
Jan 22, 2019 06:32 AM
Miles71
May 6, 2015 08:51 PM
jcddyy
Aug 19, 2011 01:27 PM
