Impala rear into a Delta?
Old Nov 27, 2018 | 04:02 AM
Fastmax32168's Avatar
Does anyone know for sure if a 71-76 Impala rear will physically bolt into a 71-76 Delta 88? I am interested in putting a 4L80E into my car along with a lower gearset. As I am sure you know there is very little available for the big olds rear, whereas you can get anything you need for one out of an Impala.
Roy
Old Nov 27, 2018 | 04:12 AM
Check it out!
https://classicoldsmobile.com/forums...erchanges.html
Our member; Monzaz, is the one to answer any questions you have about differentials. If he doesn't respond try sending him a PM.
Old Dec 21, 2018 | 04:23 PM
bigdooly's Avatar
hi, i believe it should work, all the 71-76 b body chassis the same
Old Dec 22, 2018 | 07:24 AM
The front and rear suspensions are the same on all 1971-76 B-body cars (except the wagons, of course). Yes they interchange. Keep in mind that the Chevy axle is 8.876", the Olds is 9.3".
Old Dec 22, 2018 | 11:09 AM
Thanks guys
Roy
blox84
Jan 16, 2017 03:19 PM
Holiday Joe
Apr 23, 2015 07:56 PM
71 delta88guy
Nov 18, 2014 09:44 AM
71 delta88guy
Aug 1, 2008 05:13 AM
sny74
Drivetrain/Differentials
Dec 3, 2007 03:40 AM
