Exhaust question
Old Jul 26, 2021 | 04:10 AM
arcflashfisher's Avatar
Exhaust question
I am having the 350 in my 88 convertible rebuilt and was wondering if anybody has any suggestions on what type of headers would fit. Also what's best shortys or long tubes?
The block Is bored .030 and I have #6 heads on it with a new cam that is a little hotter.
Old Jul 26, 2021 | 05:06 AM
What year Eighty Eight? The 1971-76 cars allegedly can use 68-77 Cutlass headers. No one makes headers for the 65-70 cars due to the steering box location and the lack of a market.
Old Jul 26, 2021 | 06:16 AM
It is a '75. I picked up a double hump crossmember from an earlier car.
Old Jul 26, 2021 | 07:51 AM
Kensey's Avatar
Go with whatever gives you the best clearance between the headers and the starter. I'd also suggest a heat shield and wrap the headers. Keep the starter cool!
Old Jul 26, 2021 | 11:10 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Wrapping the headers will keep them cooler but will make them rust.
Old Sep 22, 2021 | 07:35 PM
Found some shortys
I found some nice shortys from Thorntons muscle car and had them ceramic coated.
Old Oct 3, 2021 | 03:04 PM
73aussie455's Avatar
Acceleratii maxim rapidus
I like the shortys a lot, are they thorntons new style olds headers i havent seen them before.
anyone know if they will fit 455 as well, they should right?
Old Oct 3, 2021 | 06:25 PM
They fit nicely. I just put some temporary exhaust pipes on out of 2" emt. Being an electrician Has it's advantages. I believe Thorntons has a set for BBO on there website. I got these for $500 + $150 for ceramic coating. I had a hard time finding shorties that would fit my 75 Delta.
A little bit low, but it will work till i bteak the engine in and get it to the exhaust shop.
Old Nov 1, 2021 | 12:57 PM
Joezilla's Avatar
Long tube headers off the Cutlass didn't work for me. The shift rod was in the way. The long tube headers for 1975 422 fit perfectly in my 1975 Delta.
Old Nov 1, 2021 | 05:21 PM
The 68-77 Cutlass/442 headers for a BBO are the same part number.
Old Nov 1, 2021 | 05:40 PM
Joezilla's Avatar
Hedmen Header part# 58060 - blocked shift rod
Hedmen Header part# 58158 - was about 2 inches lower, shift rod clears
Old Nov 1, 2021 | 06:35 PM
What engine do you have?
Hedman 58060 is for the small block Olds. They fit 68-77 A-body cars with small block.
Hedman 58158 is for the big block Olds. They fit 68-77 A-body cars with a big block.
Of course there's a height difference. BBOs have a taller deck height.
Old Nov 2, 2021 | 04:43 AM
Joezilla's Avatar
Old Nov 2, 2021 | 04:44 AM
Joezilla's Avatar
I’ve got 403 heads on my 350, do you think the Big block headers will work?
Nevrstop
Oct 18, 2021 07:39 PM
1968_Post
Jul 8, 2013 08:29 AM
scooter123
Mar 11, 2013 07:50 PM
Mark71
Jun 27, 2011 09:43 PM
XMWZ001
Mar 31, 2011 10:44 AM
