car turned off while stopped at a red light
Old Oct 14, 2022 | 05:07 AM
bigmantinycar's Avatar
so i just became owner of a '96 88 and this happened this mroning. i was stopped at a redlight for maybe 30 seconds and the engine turned off. i had to turn the key back and turn it back on for it to drive, im wondering if this is related to maybe it needing some plugs changed or something. hopefully someone can give me some insight
Edit:so i was able to pull the codes, P0304 and P0336
Old Oct 14, 2022 | 06:44 AM
sysmg's Avatar
Did it run rough before it shut off? Or was it running perfectly and it was just like someone turned off the ignition switch?
Old Oct 14, 2022 | 09:04 AM
66_Jetstar's Avatar
I remember that issue with those cars. IIRC the issue was either the EGR was sticking open and causing the stall. They would idle rough before hand though.
I also replaced a few fuel pressure regulators as well. That was more of a straight stall with no rough running.
Old Oct 14, 2022 | 09:13 AM
gs72's Avatar
72Cutlass S
I remember they had issues with some of the MAF sensors back then. To could tap on them with a screwdriver handle and the engine would stall if it was bad.
Old Oct 14, 2022 | 10:29 AM
it was running fine before then
yeah this was a fine idle, itf it was rough it was really subtle
ok i will check that, thank you
Old Oct 15, 2022 | 02:26 PM
i noticed the car was low on oil, which i learned could cause a misfire and set off the crankshaft sensor. so i added a quart and am now going to wait. i still want to do a tuneup since its just now getting on 90k miles
bigmantinycar
Oct 14, 2022 05:31 AM
costpenn
Aug 20, 2021 03:50 PM
Jonathan67
Oct 4, 2015 12:27 AM
69442C
Jul 13, 2012 04:32 PM
FTW65W29
Oct 4, 2009 03:08 PM
