where is the drain plug for the radiator? and any other tips
Old Oct 25, 2022 | 02:21 AM
bigmantinycar's Avatar
im fairly sure my radiator is plugger so im doing a coolant flush later today. on similar cars i have seen that the drain plug is on the driver side of the radiator that that has a wingnut so just wanted to confirm. and also any other tips for doing one on this model
Old Oct 25, 2022 | 04:03 AM
Bottom opposite side from the lower hose on the engine side of the radiator.
Old Oct 25, 2022 | 07:07 AM
ok and is there a method to taking off the splash guard tabs? i know some can be easy to break if you dont do it right. and does this model require me to drain some from the engine block as well, or just the radiator/reservior
Old Oct 25, 2022 | 09:52 AM
Instead of using the radiator petcock, just remove the lower hose to drain the radiator.
Old Oct 25, 2022 | 10:07 AM
do you mean this one by the battery or is there another hose you mean. i guess if i do it this way i wont have to remove the splash guard, and this would remove all the coolant form the car, reservoir/engine included?
Old Oct 25, 2022 | 01:23 PM
Burd's Avatar
Don’t use the drain, take the hose off. Usually froze up, and the later plastic ones are hard to re-seal.
Old Oct 25, 2022 | 01:47 PM
deadeyejedi's Avatar
^^ This is what i do that petcock can be slow and drizzles antifreeze all over the place.
Old Oct 28, 2022 | 08:18 AM
harner's Avatar
1975 98 Regency Sedan
Drain it the easy way as stated above and get ready for an OSHA violation
Temeku
Mar 22, 2018 09:43 AM
Longhorncutlass
Apr 13, 2017 05:23 PM
Finn5033
Dec 2, 2012 09:57 AM
sicky olds
Dec 2, 2010 05:30 AM
ztim
Jan 8, 2008 09:40 PM
