Strange, Strange Electrical Problem Or Exorcism Required?
Old Aug 19, 2021 | 06:31 AM
costpenn's Avatar
On my 72, when the key is in the run position, if I turn my AM radio on, the GEN light on my gauges illuminates! I turn the radio off and the light goes off. Anyone ever have this happen before? I’m sure something is hooked up wrong I just don’t know what it could be!
Old Aug 19, 2021 | 09:07 AM
cfair's Avatar
I don’t know the layout of a 72 dashboard well enough, but I had a similar problem in my ‘66 big cars.
When I would turn on the headlights, it looked like the generator light was on.
Turned out the old foam gasket between the dash peanut lights and the generator light lens was completely gone. It wasn’t and electrical problem, just light bleed over from the gauge illumination light into the generator lense…
Old Aug 19, 2021 | 03:10 PM
Yellowstatue's Avatar
I would opt for exorcism. A little excitement never hurt.
Old Aug 19, 2021 | 04:08 PM
costpenn's Avatar
The Devil has been successfully cast out! The horn relay was not tight against the firewall. Must have been some weird grounding issue I’d never understand.
Old Aug 19, 2021 | 04:35 PM
Shucks, it could have been a news item for eleven!
Old Aug 19, 2021 | 10:07 PM
The only issue with the horn relay being loose would be a rattle, power comes from the junction point and grounds are hard wires supplied by the devices that operate the horns and minders.
Old Aug 20, 2021 | 03:18 PM
costpenn's Avatar
I told you supernatural forces are at play! Begone agents of Ford!!
Old Aug 20, 2021 | 03:40 PM
Cars are like people, they have bad days too.
Old Aug 20, 2021 | 03:50 PM
Bfg's Avatar
Bfg
Cars life’s matter!
kevdog442
Feb 24, 2021 04:24 PM
gkhashem
Ninety-Eight
Mar 28, 2020 07:36 AM
bigrig12
Oct 16, 2012 01:26 AM
Mattia-SS
Jun 21, 2011 08:59 AM
Joeypete
Aug 17, 2009 09:39 AM
