Blower motor
Blower motor
Got a odd one here.
It blows hot air, sometimes but other times it don't work on any setting. It doesn't work at all on "HI"
Plus I broke the grounding wire from the heater core area, is this the problem? (I kinda doubt that)
(85 Delta 88)
(85 Delta 88)
That is weird.
If I put my heater on HI, the power steering belt will screech insanely loud. and is deafning when I turn. Heater on LO, ..... not a peep.
Sounds like you have a bad connection in the system that is making contact, and then not. Perhaps like when you are hooking up speakers to the back of a home stereo and it crackles with sound for a sec and then silences.
The heater switch is controlled by cables if I remember correctly so I don't think the switch will go bad like a pwr window one would.
The ground at the heater core could be your problem for hi speed. Always repair any ground problem you may find. Sooo important.
Also, check for a wire that runs from the relay to the drivers side firewall. There is a seperate wire from in the dash, to the blower relay for high speed. Usually red, or pink. Mine burnt in the dash, took forever to trace it. Check it out, and let us know.
Yea, you need to fix the ground for sure. All I can refer to is my 70 delta. I had numerous heater, and fan issues with it. Mine uses a relay with resistors for various speeds other than hi, in hi it bypasses the relay, and uses straight alternator voltage I can hear it change speeds in hi when I accel or decel. The hi speed has a seperate fuse inline, ONE of the problems I had with not working in hi, was the fuse holder was bad, but defianatley fix the ground wire.
