74 88 WP need to replace?
Old Jun 9, 2015 | 12:35 PM
1yesfan's Avatar
When I got my car last fall, over the winter, just like 4 or 5 times what I assume is the weep hole on the top right of the WP would pee a little rad fluid or other times I would see some fluid sitting in the hole. It has not done it in about 2 months now. I figure that it is driven now perhaps the seals are holding up now?
Should I mess with it at this point or let it go? I drive the car 3-5x a week (over 7 days). I was planning on sending it out to be rebuilt so I can keep it on the car since it appears to be orig.
Old Jun 9, 2015 | 01:12 PM
It's needing a water pump. Now would also be a good time to address the timing set if it has never been changed at the same time.
Old Jun 9, 2015 | 01:14 PM
1yesfan's Avatar
change the timing chain? Why? Never heard of this on a older car with a timing chain. At 69k, does it really need it?
Old Jun 9, 2015 | 01:17 PM
Because there is a plastic lining on the gear and its 41 years old. Your half way there at this point when you remove the water pump.
Old Jun 9, 2015 | 01:20 PM
This is the first "word to the wise" warning sign.
Easier to change it in the driveway than on the side of the road.
Old Jun 9, 2015 | 01:22 PM
At 69,000 miles it probably doesn't need a timing gear yet, but by 80,000 miles they often do, and definitely by 100,000.
If you've got all of that stuff off already, it's just a matter of pulling the balancer and the front plate, and you can install a new (good quality) chain with steel gears, and never have to worry about it again.
Old Jun 9, 2015 | 01:23 PM
1yesfan's Avatar
I assume it is a straightforward pull and replace job? Is it worth having rebuilt vrs getting a reman unit? I would like to keep it orig if having it rebuilt is good as a reman unit.
Old Jun 9, 2015 | 01:42 PM
1yesfan's Avatar
hum, never done that type of repair before. I don't really have anything to pull the balancer with, then do not know how to set timing.
Old Aug 4, 2015 | 12:43 PM
1yesfan's Avatar
been driving the car all summer here in Cincy, 3-5 times a week and the WP has not seeped one time. Keeping an eye on it but at this point, aint broke, why fix it!?!?!!?
Old Aug 4, 2015 | 03:22 PM
Because it WILL break, likely late at night on an interstate, during a thunderstorm. Add the personal danger of being hit by a distracted driver to the large towing bill and then ask yourself the same question.
Water pump seals usually leak because the bearings are going bad. This will not end well.
As for the timing chain, Olds used a cam gear with nylon teeth for quieter running. These teeth wear and by 80,000 miles, they are usually nubs (with the rest in your oil pan). I've gone up to 120,000 miles on a factory timing set, and fortunately it jumped in my driveway (that NEVER happens ). I wouldn't recommend it, as a jumped timing chain can cause collateral, expensive damage.
Old Aug 4, 2015 | 03:34 PM
1yesfan's Avatar
I don't drive it at night, and if there is a chance of rain it is not driven because the top SUCKS, ha ha ha. I understand ya, just saying she has been really good to me so far.
Old Aug 4, 2015 | 08:41 PM
Yes, and, like a woman, if you are not good to her in return, you will will quickly discover there are teeth where you had not expected to find them.
Old Aug 5, 2015 | 11:04 AM
76olds's Avatar
Hookers under Hood
Ha ha ha, Oh yes and hope to hell they were false teeth.
These guys are giving you sound advice, you can run it till she breaks. The price always goes up when it breaks. Loose a day or 2 pay, towing charges ha ha even missing out on a date night could leave you shakin' more then your head .
I would get a reman pump from a local parts counter, pick up a chain and gears, rent or lend a harmonic puller and these guys will help you do the rest.
Old Aug 5, 2015 | 12:41 PM
76 Regency's Avatar
I did the pump and chain w/gears on one of my '76 Ninety Eight's and at about 145K, it was the original timing set. Just like mentioned above, the nylon teeth were worn down to nubs and there were TONS of plastic bits in my oil pump's screen. There was a ton of slack in the chain too. After putting on a new timing set, balancer, clearing out the screen, etc...the car runs 1,000 times better and now I have peace of mind too.
Old Aug 5, 2015 | 12:55 PM
1yesfan's Avatar
Do you have to reset the timing if you do that chain stuff? Well my car has 70k on it. I was planing on sending out my WP and have it rebuilt to keep the car as orig as possible. I was told that can be done and be as good as getting any over the counter unit?
Old Aug 5, 2015 | 01:01 PM
76 Regency's Avatar
If you have the service manual, it would be a big help.
In short, once you pull the timing cover off, line up the timing marks, remove the chain and gears and put the new ones back in making sure the marks line up the same way as the original set. This will keep the cam and crank synced correctly. Since you're replacing a 40 yr old chain, you will likely need to adjust the timing at the distributor a bit but that's the easiest part of the process, by far!
Old Aug 5, 2015 | 06:40 PM
The Tin Man's Avatar
The Tin Man
You guy are great.... listen to them they KNOW!!!!! change before it brakes
Old Aug 6, 2015 | 06:34 AM
1yesfan's Avatar
I do have a shop manual. Ha ha ha. I know I should do the pump. Was not planning on doing a timing chain.
Old Sep 27, 2015 | 04:54 PM
1yesfan's Avatar
I have the wp pump off now. How hard is it going to be to take off the balancer? Where can I find the new timing chain stuff?
Old Sep 27, 2015 | 05:22 PM
1yesfan's Avatar
see all types of timing chain things on Ebay. Any suggestions to what is best?
Old Sep 27, 2015 | 05:33 PM
1yesfan's Avatar
When I pulled the pump there is the plate there now, is there a gasket behind that keeping oil from leaking from behind it? It is moving a little at the top where the WP bolts are out. If I pass on the timing chain repair, is the thing going to leak oil now even once the pump is back on if there is a gasket behind it that I have not disturbed on the top part of the plate?
Old Sep 27, 2015 | 06:07 PM
1yesfan's Avatar
is this the right part# for the t-stat? 131-73 Should I stay stock? 190 or can I go colder?
Old Sep 29, 2015 | 05:36 AM
1yesfan's Avatar
well replying to my self jere I finally recalled that I DO have a fact serv manual. So I pulled it out. It says not to put a tstat in the car over 195. Mine had a 180 in it. I suspect 180 is not factory and that I should do back to 195.
Old Oct 10, 2015 | 07:51 PM
1yesfan's Avatar
Had Water Pump Man do my pump. Installed and car is back on the road. Put 195 stat in it. Nice and warm heat now baby.
One odd note after all put back together the pulley that mounts to water pump is wobbly looking when the car is running. Not sure how that is that way now. I did not drop it when things were apart. I have the non clutch fan (no ac car) perhaps I torqued down a fan bolt to hard? Maybe the rebuilder of the pump dropped it on the pulled monter and it is warped.
Old Oct 12, 2015 | 12:31 PM
1yesfan's Avatar
No leaks yet. that is a good thing
Kirk455
Body work
Jul 2, 2015 11:48 AM
atownhockey19
Bravada
Mar 6, 2012 11:49 PM
b350m
Aurora
Aug 3, 2011 03:04 PM
gearheads78
Sep 3, 2008 11:12 AM
julius
Aurora
Sep 17, 2006 06:56 PM
