1978 Delta 88 Subframe bushing kit
Old Yesterday | 10:03 AM
SparkyMHG's Avatar
I'm doing a frame off restoration on my Holiday. I figure while I'm to this point, I might as well replace the subframe bushings. The trouble is where can I find them or what can I use that interchange with them.
Old Yesterday | 11:16 AM
rocketraider's Avatar
Oldsdruid
What kind of subframe has been installed on the car?
These cars are body-on-frame construction with full perimeter frames. Body mount pucks should be same as a similar year Impala/Caprice, if you can find those.
Old Yesterday | 11:58 AM
newmexguy's Avatar
Yep, that's a full frame car. Believe '77 to '85 are pretty much the same, in terms of mount locations and type.
Old Yesterday | 12:22 PM
^^^THIS^^^
If your car is a 78 it's body on frame. If it's 20 years newer from 98, then you do indeed have a front subframe that would need bushings eventually.
Old Yesterday | 12:56 PM
SparkyMHG's Avatar
Originally Posted by Olds64
^^^THIS^^^
I do have bushings on the front on the framework that the radiator sits on.
Does anyone have any links or sizes that would work? It seems to have a bushing on each side that is not bolted too
BluesmanT
October 25th, 2021 03:47 PM
jwindarwin@gmail.com
October 9th, 2015 07:10 PM
bigdooly
April 22nd, 2015 09:27 AM
MASH4077
Suspension & Handling
26
July 19th, 2011 04:46 PM
DAN76
June 15th, 2009 02:30 PM
Quick Reply: 1978 Delta 88 Subframe bushing kit
