1978 Delta 88 Subframe bushing kit
Old Oct 30, 2024 | 10:03 AM
SparkyMHG's Avatar
I'm doing a frame off restoration on my Holiday. I figure while I'm to this point, I might as well replace the subframe bushings. The trouble is where can I find them or what can I use that interchange with them.
Old Oct 30, 2024 | 11:58 AM
newmexguy's Avatar
Yep, that's a full frame car. Believe '77 to '85 are pretty much the same, in terms of mount locations and type.
Old Oct 30, 2024 | 12:22 PM
^^^THIS^^^
If your car is a 78 it's body on frame. If it's 20 years newer from 98, then you do indeed have a front subframe that would need bushings eventually.
Old Oct 30, 2024 | 12:56 PM
SparkyMHG's Avatar
Originally Posted by Olds64
^^^THIS^^^
I do have bushings on the front on the framework that the radiator sits on.
Does anyone have any links or sizes that would work? It seems to have a bushing on each side that is not bolted too
Old Nov 2, 2024 | 06:45 AM
You might want to get a factory Chassis Service Manual, which shows you the locations of the body mounts. As noted, your car does not have a "subframe". It is a full frame car. The core support mounts to the front frame horns with two bushings. The rest of the body uses a number of bushings with through bolts and pads without bolts at different locations depending on the body style. And just to confirm you ARE talking about the body-to-frame bushings and not the suspension bushings, correct?
Old Nov 2, 2024 | 06:54 AM
SparkyMHG's Avatar
Yes body to frame bushings
Old Nov 2, 2024 | 07:09 AM
SparkyMHG's Avatar
BTW, I just ordered a Chassis Service Manual. I hope it will have sizes or part numbers with that too
BluesmanT
Oct 25, 2021 03:47 PM
jwindarwin@gmail.com
Oct 9, 2015 07:10 PM
bigdooly
Apr 22, 2015 09:27 AM
MASH4077
Suspension & Handling
26
Jul 19, 2011 04:46 PM
DAN76
Jun 15, 2009 02:30 PM
