1968 delmont 88 parts sourcing help
Old Feb 7, 2014 | 06:52 PM
DigitalFubar's Avatar
ok im looking for a few parts that i cant seem to find..
1. windows trim/rubber for the doors and rear windows
2. trunk seal rubber
3. door trim rubber
and just any place that would carry parts for my car would be great..
and lastly.. minus a full engine tear down what would give me a few extra horse power?
I currently have these..
1. holly street dominator intake.
2. holly carb that i cant rightly identify heres the numbers i found..
facing the front of the carb from the bumper at the first float /barrels..
I see.. 331D-8 and right below it in line i see 1582 now the D might be a messed up 0 but it looks like a D..
then below the bowl on the front right i see 10569
Old Feb 7, 2014 | 07:38 PM
tru-blue 442's Avatar
Old School Olds
Can you source the rubber for a 68 Delta 88?
I would think they would be the same pieces?
Old Feb 7, 2014 | 10:49 PM
mrolds88's Avatar
Carb is a 3310. Try Steele or Fusick for the rubber parts. As far as more power, Better exhaust, cam, cold air intake. You will probably want to look into better gears too.
Old Feb 7, 2014 | 11:00 PM
well I do have a 2 1/2 or may be 3.. i forget lol flow master exhaust.. no can that i know of.. by cold air intake you mean like the ones found on the ricers? and as for gears are you talking in the diff or the tranny? sorry semi noob here
also what disk set up can i go to for the fronts?
Old Feb 8, 2014 | 12:38 AM
nsnarsk65cutlass's Avatar
1969 70 disc- spindle setup is the same.
Old Feb 8, 2014 | 07:14 AM
mrolds88's Avatar
Gears in the rear axle. As far as the cold air intake, I'm not a fan of the ricer style intakes as they still pull underhood air in, its still hotter than the air in front of the radiator support. Here's a pic of what Ford did in the early 60's. Disc brakes, 69-70 will bolt on. 68 had them too, but stay away, Expensive and hard to get parts for the 68's. 69-70 rotors are not produced any longer. There is a guy on here that has found a suitable replacement.
Old Feb 8, 2014 | 05:33 PM
Dustin1706's Avatar
'68 Delmont owner also. I just ordered a full set of replacement rubbers and seals for mine. Metra makes them and I ordered mine from Rock auto.
http://www.rockauto.com/catalog/rafr...arcode=1440846
Old Feb 8, 2014 | 07:01 PM
oldspackrat's Avatar
I have a nice '68 Delmont 4 door, would any of the stuff fit your car? Call me?
Scott
c 317-727-7041
Old Feb 8, 2014 | 11:40 PM
Hi scott ill give you a call in the morning.. just saw this reply and it is late..
Im not sure what would fit and what wouldnt.. Is your car disk brakes in front?
Does any one else know if any of the molding would fit or trim?
Old Feb 9, 2014 | 04:53 AM
to bad it didnt pull up the parts you ordered! id just get the same lol..
Old Feb 9, 2014 | 04:54 AM
hmm there is a site that sells this sort of set for are cars ill see if i can pull it up.. but its stupid exspensive
Old Feb 9, 2014 | 05:07 PM
There are a couple(few?) guys on here that have some disc brake parts for the big cars. I might have a set of spindles, I'll have to check my stock. If you use the search function on here, you might have some luck. Try different wordings like Delta disc brakes, Delmont disc brakes, disc brakes, etc...
Old Feb 10, 2014 | 12:36 AM
YEA your correct. i should use the search function more.. i do use it but i never seem to find any info on what im looking for.. like 1968 delmont 88 disk break conversions.. i find cars that are close but different.. no direct info.. but i might need to broaden my phrasing..
Old Mar 12, 2014 | 01:16 PM
rocwal's Avatar
unless Things have changed since I did my 68 ninety-eight convertible disc change over , the only disc's that will fit OLDSMOBILE CARS are Oldsmobile Disc' brakes 67 thru 70 big cars only .as someone stated they are far and few around ,costly and heavy to ship . that being said I know of a few yards that have some still on the cars , cost around $300.00 + take off + shipping . then you need to rebuild the calipers and turn the rotors . I guess new calipers are available , not rotors .
rocwal
Dan B
Dustin1706
Apr 21, 2014 11:15 PM
DigitalFubar
57
Mar 24, 2014 10:01 AM
orthoK
Oct 2, 2012 08:00 PM
TheBigBlueBoat
Body work
Apr 28, 2012 02:55 PM
