1956 Oldosmobile 88 steering gear box
Old Dec 11, 2009 | 08:21 AM
Yanqui84@gmail.com's Avatar
Hello,
My brother recently bought a 1956 Oldsmobile 88th sedan. His Steering gear box have a leak, and we want to replace it or repair it and we need some suggestions and where can we get a new steering gear assembly, or do you guys recommend to repair it (where can I get the kit?). Thank you guys for the help.
Here are some pictures:
Old Dec 11, 2009 | 09:43 AM
citcapp's Avatar
That is a sweet ride. Try http://www.rockauto.com/ They have the seals your looking for. Its rare that you have to replace the box. The first thing I suggest is to get your hands on a shop maunual. You can find these on e-bay just type in 1956 Oldmobile. Good luch
Old Dec 11, 2009 | 10:03 AM
Citcapp,
I got some new info from my brother and maybe I did not stated correctly the first time:
The problem he is having is that the Power Steering sends fluid to the king pin (please correct me if am wrong) but the king pin is rejecting that fluid so thats why the steering is hard and is like if he had no P/S.
Old Dec 11, 2009 | 10:07 AM
Welcome, that is an awsome car!
You were correct the first time. The power steering pump sends hi pressure fluid to the steering gear box. IF the steering gear box is leaking you might also check out Kanter or Fusicks for replacements or rebuild kits.
Old Dec 11, 2009 | 04:07 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Contact Chip at Power Steering Services in Springlield, MO. Here is the link:
http://www.powersteering.com/
Chip is great guy and will rebuild your steering sector to like new. He did a 54 for a friend of mine. It was like new. I am confused about fluid going to the king pins. King pins are part of the suspension and attached to the control arms. I am not sure but I think the 56 has ball joints instead of king pins. The 54 still has king pins. The 54 has a huge sector with power steering and the shaft comes out and runs all the way to the steering wheel. There is no rag joint connecting the column to the sector.
Old Dec 11, 2009 | 04:09 PM
redoldsman's Avatar
By the way, nice car although I don't care for the portholes. I like the unusual color combo. It is going to be a neat cruiser.
Old Dec 11, 2009 | 05:58 PM
rket56's Avatar
I was going to ask if it had power steering, but I see that has been answered. I agree don't mess with this, send it for rebuild. It's not cheap. I would get the pump and the sector rebuilt together along with the new hoses. Nice ride, but the 56 still has kingpins. I replaced mine with a kit that uses roller bearings. Good luck and welcome to the site, lots of helpful people and good infor. Rket56
Old Dec 12, 2009 | 01:10 PM
I've heard of Chip before. Supposedley his work is top notch. The parts come back looking like new, and he can even put a quicker ratio in your steering box. You get what you pay for! I might send my unit to him in the future.
Old Dec 16, 2009 | 12:32 PM
Thank you guys for all the help, most likely I will be sending it to Chip the pump and the gearbox after I get my car from my mechanic because my differential had a leak and we getting that fix.
Old Dec 17, 2009 | 08:32 AM
BTW, what are the tires on your car? They are AWSOME! I've been thinking about getting wide whitewalls for my Olds this summer.
Old Dec 17, 2009 | 08:47 AM
Hello Olds,
The tires are Supreme 78 L 78-15 Tubeless
dahl1car
Jul 21, 2017 07:47 AM
Al Graaf
Sep 16, 2012 03:29 PM
croozer
May 11, 2012 09:39 AM
defiant1
Jan 26, 2011 03:54 AM
nohn
Jul 7, 2008 11:55 PM
