front suspension change for 350to455 engine swap?
Old Jan 1, 2009 | 08:54 PM
delta881972's Avatar
my 72 delta88 is a stock 350/th350 car and am currently building a 455 and looking for a th400 to swap into it. im sure the extra weight in the front will require front suspension modification but not sure how to approach this.... is the frame the same on the 88's(or even the 98's) that came stock with the 455 to where it would be a simple unbolt/rebolt to swap fronts?
any other helpful tips to steer me in the right direction would be GREATLY appreciated! please reply to my email --- harleyjasondavidson@hotmail.com
thanks everybody!
Old Jan 1, 2009 | 10:01 PM
88 coupe's Avatar
Junior Member
Originally Posted by delta881972
........ please reply to my email ........
Defeats the purpose of the forum.
Norm
Old Jan 1, 2009 | 10:07 PM
ok. anybody with USEFULL advice instead of gripes?
let me rephrase: please reply to my email AS WELL since my access to this website is limited at work and not available at home.
Old Jan 2, 2009 | 06:54 AM
thanks everybody!
The only difference from the factory was the spring rate used in the front springs. You can change these if you want, but in reality the difference in weight will be on the order of 100 lbs. This will be virtually unnoticeable in the ride height.
If you do plan to change the front springs, you MIGHTASWELL rebuild the front suspension...
Also note that under the User Control Panel you can elect to receive email copies of responses to threads that you have subscribed to. This should solve your website accessibility problem and provide you with instantaneous notification of a response.
dre
Drivetrain/Differentials
Aug 31, 2011 11:04 AM
bourbon
Suspension & Handling
Jan 16, 2010 06:07 PM
oldjunk
May 10, 2009 06:30 AM
shaks 442 clone
Jul 29, 2007 09:27 PM
