front suspension change for 350to455 engine swap?
my 72 delta88 is a stock 350/th350 car and am currently building a 455 and looking for a th400 to swap into it. im sure the extra weight in the front will require front suspension modification but not sure how to approach this.... is the frame the same on the 88's(or even the 98's) that came stock with the 455 to where it would be a simple unbolt/rebolt to swap fronts?
any other helpful tips to steer me in the right direction would be GREATLY appreciated! please reply to my email --- harleyjasondavidson@hotmail.com
thanks everybody!
thanks everybody!
thanks everybody!
thanks everybody!
If you do plan to change the front springs, you MIGHTASWELL rebuild the front suspension...
Also note that under the User Control Panel you can elect to receive email copies of responses to threads that you have subscribed to. This should solve your website accessibility problem and provide you with instantaneous notification of a response.
