What am I dealing with pics 394139
Old May 22, 2014 | 10:50 AM
mr sunset's Avatar
[attach]Type O rearend detail 006.jpg[/attach][attach][attach]Type O rearend detail 016.jpg[/attach][/attach]
Old May 22, 2014 | 10:51 AM
mr sunset's Avatar
Whats the simple posi upgrade here, 455 w/400 turbo trans in gm a body.
Old May 22, 2014 | 01:16 PM
I can't make out the numbers before "GM" on the edge of the ring gear. Those would be the number of teeth on the ring and pinion gears; divide them and you get the ratio, then once you know the ratio you will know what series carrier you need.
The other info is just the axle housing, which doesn't tell you much about the gears inside it. The gear ratio is what will determine which carrier you need.
Old May 22, 2014 | 03:04 PM
mr sunset's Avatar
The carrier has a 358 cast into it. does that help.
the ring numbers look like 14 A 39
The two letter axle stamp is SA
Confirmation on the numbers, I counted the ring and pinion
Old May 22, 2014 | 04:48 PM
Hard to say from that pic other than an open differential. There has to be another number to the left of that 4A. Is it by chance a 37?
Old May 22, 2014 | 04:56 PM
Octania's Avatar
39/14 = 2.78
Sounds like a final drive ratio to me.
Old May 22, 2014 | 05:12 PM
Where did you find the 39 on that ring gear Chris?
Old May 22, 2014 | 06:52 PM
mr sunset's Avatar
Yes 39/14. I counted the ring and pinion. We also have an SA code. This sounds like a one legged freeway machine. Is there anything good about this rear end?
Old May 22, 2014 | 08:26 PM
SA code was for 2.73 in 1971 and 72. Is your car by chance a 1970 Cutlass? That would match the SA code for 2.78.
Old May 23, 2014 | 10:47 AM
mr sunset's Avatar
Not a '70 Cutlass, This was in a '67 GS400 I acquired. nothing in the drive train was original and the upgrades seem to be valueless. I'm new at the BOP so I am learning here. Any suggestions on a direction I should take. build this or look for a factory posi. If so, what rear end will bolt up.
Thanks for the help. hours of research here.
Old May 24, 2014 | 10:32 AM
Octania's Avatar
Evidently I pulled it from thin air.
I thought it was in the picture provided, but now I do not see that in the picture
Old May 24, 2014 | 11:47 AM
Without seeing the axle it's hard to say. If it's a 12 bolt O style - it's hard to get gears. If it's a 10 bolt 8.5 it's a great rear end to modify to your liking IMO.
Originally Posted by Octania
Evidently I pulled it from thin air. I thought it was in the picture provided, but now I do not see that in the picture
LOL so now you're clairvoyant to boot...good guess BTW!!
Alex72cutty
Feb 17, 2014 08:41 PM
rhett838
Mar 7, 2013 08:14 AM
MrLightning
Sep 5, 2012 07:59 PM
klovett
Hurst/Olds
15
May 11, 2012 06:43 AM
sicky olds
Feb 3, 2012 06:18 PM
