What am I dealing with pics 394139
[attach]Type O rearend detail 006.jpg[/attach][attach][attach]Type O rearend detail 016.jpg[/attach][/attach]
I can't make out the numbers before "GM" on the edge of the ring gear. Those would be the number of teeth on the ring and pinion gears; divide them and you get the ratio, then once you know the ratio you will know what series carrier you need.
The other info is just the axle housing, which doesn't tell you much about the gears inside it. The gear ratio is what will determine which carrier you need.
The carrier has a 358 cast into it. does that help.
the ring numbers look like 14 A 39
The two letter axle stamp is SA
Confirmation on the numbers, I counted the ring and pinion
Not a '70 Cutlass, This was in a '67 GS400 I acquired. nothing in the drive train was original and the upgrades seem to be valueless. I'm new at the BOP so I am learning here. Any suggestions on a direction I should take. build this or look for a factory posi. If so, what rear end will bolt up.
Thanks for the help. hours of research here.
LOL so now you're clairvoyant to boot...good guess BTW!!
Alex72cutty
Feb 17, 2014 08:41 PM
